Results 1 to 13 of 13
Chain Oilers
    rides bikes
    Nov 2014
    Chain Oilers
    Anybody run a chain oiler? I always made fun of these, but I'm churning through chains on my winter bike from all the salt and shit, so I'm considering one.
    Don't want to spend big money on one. I found the "Loobman" one which is cheap, but haven't found a good source to buy it.
    Re: Chain Oilers
    I've got an old ScottOiler (version 7 I think) that I'd let go for real cheap if you want to try it.
    I93/495
    Re: Chain Oilers
    I ran Scott Oiler on my old Tiger. Some things are nice about it, others suck.
    My current Tiger and the dirty toy don't have one. I went back to just spraying it every now and then. Sometimes I spray it a few times a day on trips likes this. Over 10k on the current chain and that's 're chain that saw the Translab.
    Chain Oilers-20160829_115159-jpg
    2012 Tiger 800 XC
    Re: Chain Oilers
    I'm running a Scottoiler on my Wee, also ran one on my KLR.
    I won't ever run another after the Wee is gone. Just not worth the mess.
    The Scottoiler is best as leaving a puddle of oil on my garage floor and making the back of my bike a complete mess. Doesn't help lube the chain much. Not sure how the hell it manages that.
    2016 BMW S1000XR
    rides bikes
    Nov 2014
    Re: Chain Oilers
    Thanks for the insights. I don't have a chain guard on the bike in question, so that might get messy in a hurry. It also gets parked in a different spot in my garage every night, so it's not like I could leave cardboard down.
    I'll keep looking into it...keep the opinions coming!
    Re: Chain Oilers
    what are you using for lube ? drip rate?
    I have certainly had the issues you are having, but once I got the lube (ATF) and drip rate 1/50 seconds, I no longer had those problems
    do you have your drip tube aimed at chain ? or sprocket ?
    Re: Chain Oilers
    Drip rate isn't consistent. Using a mix of oil/atf. Using the dual nozzle upgrade to drip right onto the chain sideplates.
    Nothing comes out while riding, or it just flies off onto my wheel/fender.
    Puddle after every ride under the bike. The unit itself is located in my tool tray under the seat, so it's not completely upright. That may be hurting me. Finding a good place to mount it on a wee wasn't the easiest thing.
    2016 BMW S1000XR
    Re: Chain Oilers
    What version do you have? The ones I've used are all vacuum-operated. If the engine isn't pulling a vacuum, it won't dispense oil. That way, no drips on the garage floor when you're not riding it.
    Re: Chain Oilers
    Clayton just sucks so much that it keeps dispensing until he vacates the garage.
    Re: Chain Oilers
    Re: Chain Oilers
    I've heard nothing good about the dual nozzle outlets, except the hype to get you to buy one.
    single nozzle, on the sprocket, not the chain, pick a viscosity and brand and stick with it, I use Walmart Supertech Dextron III
    in winter, I mix in a little K1 and let it get a little sloppy
    Re: Chain Oilers
    Vacuum. Still leaves a first sized puddle.
    2016 BMW S1000XR
    Re: Chain Oilers
    I had an issue on my SV650, my original routing of the vacuum line had it too close to the exhaust, melted it right in half while running, sealed both sides so that I didn't have a vacuum leak, and my Scottoiler wouldn't shut off
  1. WTB:525 chain
    By duganc1717 in forum For Sale
    Last Post: 09-12-09, 07:20 PM
  2. Replies: 0
    Last Post: 05-03-07, 12:51 PM
  3. Best chain to get
    Last Post: 05-23-06, 06:46 AM
    Last Post: 06-29-04, 12:23 AM
    Last Post: 05-28-03, 09:17 PM
