Ninja not as stealthy anymore? Need insight please.
Swapped wheels less than 60 miles ago. New tires are mint BTW. Go Avon! Who?
Out for a ride, squeek coming from down low, left side of the bike, possible ahead of the engine in terms of location..??
Not too sure so I have started a process.
My chain was cleaned for the tire change, only applied lube after yesterday's ride.
Possibly the speedo cable.
Possibly brake pads are still re-seating after the re&re of the front wheel.
Possibly brake pads need replacement as they looked thin.
Possibly wheel bearings? Axel design prevents over tightening so may be a long shot.
The sound is not constant.
It is loud enough to hear at speeds around 60kph with my visor lifted, or not.
It is not likely coming from the engine as I'm able to almost get noise from the issue while rolling the bike. I think this may be a clue?
The sound starts off light and increases then fades.
Bike seems to roll with the same amount of effort.
I have not put the front up on the stand yet.
Performing a side to side while in my lane doesn't seem to have any effect.
I have not tested out the chain since applying lube, tension is good. Chain and sprockets are new-like.
It is not the fairing or related bits that hang on the bike.
Thanks for any insight.
