Results 1 to 20 of 20
Stripped threads in oil pan
    Member mi1knc0okies's Avatar
    Oct 2010
    Provi
    Was doing some routine maintenance and somehow stripped on the threads in the oil pan of my 07 r6. The threads on the bolt look perfect so its the oil pan i need to fix. I'm not really sure whats the best way to go about this other than finding a oil pan somewhere. Anyone have any suggestions? I was trying to make the Bomoto day monday but looks like I'll just be spectating and snapping pictures.
    Lifer JohnnyV's Avatar
    Westborough, MA
    Wirelessly posted (Blackberry Bold 9930)
    Been there, done that. Heli-coil. Back when I made that rookie mistake it was a $50 lesson learned, local dealership did it.
    Oct 2010
    Provi
    Re: Stripped threads in oil pan
    Did you bring them the oil and or did they do it while everything was attached to the engine? I guess I'll call a dealership tomorrow and see what they can do since I don't have any days off till monday.
    Derry NH
    You sure the pan didn't split up the side? The R6's love doing that if you over tighten it.
    Westborough, MA
    Luckily although mine was stripped, I was able to get it to the point where it would go in and snug up enough so that it was a slow weep while running, maybe two drops per minute. I was able to carefully limp it to the shop which luckily for me was only a few miles from my house. I brought them the whole bike. I assume they just dropped the pan with the motor in the bike, or were able to drain the oil and do it with the pan still on the motor.
    Westborough, MA
    FYI... there is an oil pan for your bike on ebay, buy-it-now $25 and its located in Brockton. Contact the seller, tell em you'll buy it now and pick it up.
    http://www.ebay.com/itm/06-07-YAMAHA...sories&vxp=mtr
    Oct 2010
    Provi
    Quote Originally Posted by Eric Baker View Post
    I was peeling metal shavings off the treads of the plug. I felt some smooth parts on the pan too. I'll have to double check for cracks but it didn't look like there was any earlier.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    hurry 13 minutes left in that auction
    Oct 2010
    Provi
    after searching on the r6-forums it sounds like this happens a lot. I emailed that guy about the pan. http://www.r6-forum.com/forums/showt...hlight=oil+pan
    Thanks for the help!
    Senior Member SVenpointsixtwo's Avatar
    Jeffersonville, VT
    I don't know if this helps for the R6, but I just did the exact same thing on my DRZ400 (I'm blaming the previous owner for overtightening the drain bolt!). Car parts places will have a "single oversize" drain bolt that self-taps its way up your ruined threads and is just slightly larger than the existing hole. Comes with a gasket and worked perfectly!
    I was definitely worried, as the DRZ pan is part of the engine case castings... not replaceable!
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Oct 2010
    Provi
    Quote Originally Posted by SVenpointsixtwo View Post
    This might be my only option. A friend also told me about a rubber plug with a metal core that expands. At this point my chances of making the track day on Monday arent looking very good. the guy with the oil pan hasn't messaged me back nor do any of the dealerships near me have a gasket in stock.
    Nov 2009
    Bristol County
    Might be able to use liquid gasket (aka RTV) in place of a gasket if you're really desperate. Autozone sells some. It'll be a bitch to get off later if/when you go to put the real gasket in. Make sure to get the type that is good for oil-contact, and use extremely sparingly.
    nedirtriders.com
    Aug 2009
    I'm thinking you do not want to go to a track day with any type of jury rigged solution to this problem. Even if it passes the organization's tech, the risk to yourself and other riders should be considered.
    Oct 2010
    Provi
    Exactly why I'm depressed right now. I rather not red flag the day or some how blow my engine and sit this one out than ride all day but constantly be worried something will go wrong.
    Did you get that pain for it?
    CCS/LRRS #83
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Glad I'm not the only one that's done this. It was on my race bike and I ended up going the ebay route instead of jerry rigging something for the same safety reasons that were mentioned.
    This is a known problem on R6's?
    CCS/LRRS #83
    Derry NH
    Not this particular problem. I'm a mod on an R6 forum and there used to be countless posts of cracked oil pans from over tightening the drain plug. I've also seen a bunch of stripped but oil pans in VW's at work from the same thing because they're aluminum.
    Oct 2010
    Provi
    I did a search on the R6 Forums and I didn't see anything about cracked oil pans but quite a few people had the same problem as me. The ebay guy never replied about the oil pan. I'll be ready for the next track day.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Helicoil or up-drill and tap to the next bigger size. Both are viable fixes. It only takes a few minutes to fix......
    If you have the tools.
  1. Off Topic threads not appearing in Recent Threads list.
    By ZX-12R in forum Site Info & Suggestions
    Last Post: 09-29-15, 10:05 AM
  2. All stripped down and ready for winter...
    By reiobard in forum Bike Maintenance
    Last Post: 02-05-10, 06:03 AM
  3. stripped fairing bolts
    By DaSarge in forum General Bike Related
    Last Post: 04-24-08, 05:49 AM
  4. Stripped bolt or pan?
    By FastJohnny in forum Bike Maintenance
    Last Post: 04-05-07, 03:10 PM
  5. stripped drain plug
    By Gangsta SV in forum Bike Maintenance
    Last Post: 09-12-05, 02:14 PM
