Zip-Tie Alley Racing
LRRS/CCS #103
LRRS/CCS #103
I found one of these brushes at the local bike shop
Motorcycle Chain Lube - webBikeWorld
It works great. Hits 3 sides of the chain at once. The article has some good info on chain cleaning too.
I use WD40, rotate the wheel while I spray on (chain should be warm, not hot), then scrub with the brush until I see the gunk spread across the chain, then wipe clean with high quality paper shop rags. Wash, rinse, repeat, until the chain is clean.
I find that cleaning the sprockets is a real pain in the ass though... but I've never taken off the rear wheel myself.
In the article posted above there is a section telling you why you shouldn't use WD40...they say to use kerosene or diesel.
"Harley Davidson: The most efficient way to turn fuel into noise without the risk of power and handling."
Selltekk.
-'04 Yami YZF600R (NOT R6)
- Uberfast Blue color
-Two Bros. Exhaust
-OES Sliders
-Helibars
-Mototeck Flushies
-Factory Pro Shift Kit
<a href="http://www.linkedin.com/in/davefortin" ><img src="http://www.linkedin.com/img/webpromo/btn_viewmy_160x25.gif" width="160" height="25" border="0" alt="View David Fortin's profile on LinkedIn"></a>
if you read through here, you'll see some comments about WD-40 might stay in between the rivets and cause the lube/wax to not stick to the chain as well. There's also another comment about that Grunge Brush, which I actually bought recently too. I'm using that Chain Cleaner 611, and Chain Wax with the grunge brush
The Grunge brush works pretty well. I've found it helpfull to get a bunch of cheap dollar store type, stiff bristle tooth brushes.
http://youtube.com/watch?v=80CESYb6bbM
I do it under the swingarm. Not sure why that guy did it above. Doing it below is better because you got less of a chance of shit spraying/dripping on parts of your bike.
DBConz -
Is that an african short hair in your avatar?
