Results 1 to 8 of 8
Click click but no turn?
    Member Zolden's Avatar
    Jul 2005
    NJ/NY
    My '95 ZX7 was last started january 5th, and it ran completely fine. I came back down to school the next day. My father tried to start my bike two weeks ago. It had been sitting since Jan 5th... The starter clicks, but apparently there is no turnover or engine-attempt. The battery was freshly charged. Is it possible the carbs are all gunky now and thats whats causing this? Or should I start looking into this as a starter issue?
    I won't be able to look at it personally until June 1st but I was looking for any 'heads up' on things that could cause it to not start now after sitting in a shed for only 3 months.
    '19 Husqvarna FS450 Race
    Lifer smf's Avatar
    Nov 2006
    definitely not the carbs, your engine would turn over. sounds a lot like starter to me.
    Scott
    Waterbury, VT
    Check for a loose connection - battery connections, cables, etc. It might be the battery itself - older batteries can take a charge, but not give enough amperage. If you have a set of jumper cables or a booster try that.
    SSearchVT
    Just Registered wylee's Avatar
    Jul 2006
    Northern NH
    Sounds like a dead battree. Leave the charger hooked on and see if it'll turn over.
    Health nuts are going to feel stupid someday, lying in hospitals dying of nothing.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    I'd bet its the battery.
    Sometimes you get enough power to get the solenoid to click but
    not enough to get the starter to turn.
    Take a volt meter to your battery and see its output.
    Should be over 12.
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Obviously check the battery...
    Now for another couple lessons on these things...key in ignition...jiggle key when in ign barrell while hitting the starter button. Sometimes you gotta hit the starter button a couple times for it to catch.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Battery (if not reading 12V+ after charging), then starter and/or starter solenoid. You can try jumping the starter with a screwdriver to eliminate the solenoid.
    Apr 2004
    boston burbs....
    sometimes with my old zx6r i'd have to lean the bike over way on the left and star ther over.. it was a combo battery/ carb thing
    hmmmm......
