Bike is a BMW S1000XR. Went to move the bike around the garage and was having a hard time pushing it around. First thought the tires were flat or something but they're fine. So with the bike in 1st gear and clutch pulled in there is a lot of resistance at the wheel. Basically with the bike turned off and on the stand withrear wheel off the ground, 1st gear and clutch lever pulled all the way in, I could barely turn the wheel with all my strength. When in neutral the wheel turns freely. Also when I have the rear wheel in the air, with the engine running, 1st gear and clutch pulled in, I cold more easily turn the wheel. But it reverts back to the same behavior when I turn the bike off. Clutch lever free play is adjusted correctly.
It did sit through the winter with oil that had about 3500 miles on them, but I've already changed to fresh oil.
How do I fix this?
