Results 1 to 8 of 8
Clutch hub removal
    100 X slower than Gerard scootertrash's Avatar
    Alton Bay, NH
    Clutch hub removal
    So I'm trying to remove the clutch hub on my ZX6R. Granted there is a special tool you can use to hold the hub while taking the nut off. I don't have one. I've seen others get the hub off by locking up the rear tire and using the drive train to keep the hub from spinning. I've tried that and am not having any luck. I'm using a breaker bar and the nut won't budge. I'm afraid I'll break something. I'm assuming it's a standard thread, not reverse thread nut (?). Does anyone have any other tricks to try before I go out and spend the money on the tool, which is probably not cheap.
    Oct 2007
    Peabody Assachusetts
    Clutch hub removal
    I know this is not the answer you are looking for but I use an impact gun and it zips right off. No special lock up tool required.
    Lifer LuvDog's Avatar
    Ashland, MA
    Clutch hub removal
    The trick if you don't have the clutch hub holding tool is to get an air impact wrench.
    2003 ZX7R
    1995 916
    Waterbury, VT
    Clutch hub removal
    Sometimes you can get lucky by taking a few steel clutch plates and clamping them together with a set of vise grip plyers. The plates are junk when you're done. Hope this helps. Good Luck...
    SSearchVT
    Alton Bay, NH
    Clutch hub removal
    Thanks for the advice.
    I borrowed an impact wrench and it worked great.
    Of course, when I reassemble the clutch I'll need something to hold it so I can torque it correctly, but I guess I'll figure that out next week...
    Maybe I'll have to pick up a few extra steel clutch plates and fabricate something.
    Clutch hub removal
    Gordo, what's your address? I'll mail you my clutch hub holding tool.
    degs
    Oct 2007
    Clutch hub removal
    degs
    Now that's what I'm talking about!
    KB KB's Avatar
    Manchester NH
    Clutch hub removal
    I's uses onea dem rubber strap wrenches from sears.
    Yup yup!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Clutch spring...lessen clutch pull
    By black in forum General Bike Related
    Last Post: 06-29-20, 10:25 AM
  2. Wanted - Parts & Tools | Clutch perch bolt for 03+ SV650 (or complete perch) also 00-03 GSXR clutch perch
    By juha_teuvonnen in forum Wanted
    Last Post: 05-22-18, 10:57 AM
  3. For Sale - Parts & Tools | Yoyodyne slipper clutch, Ducati 848 wet clutch
    By jwm2k3 in forum For Sale
    Last Post: 04-27-17, 10:07 AM
  4. Clutch Lever Pivot Bolt/Nut -- stripped/stuck -- removal
    By dhawks in forum Bike Maintenance
    Last Post: 03-13-10, 06:45 AM
  5. Bar end removal
    Last Post: 04-27-05, 04:19 PM
