Results 1 to 14 of 14
Clutchless shifting..
    If I'm going WOT, after I get out of first, I sometimes upshift without using the clutch. Is this bad for the tranny at all?
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    nope
    Ya, once you're out of first & in 2nd or higher, there's no problem w/ it... just put pressure on the shifter w/ your foot, quickly close the throttle a bit to relieve the load on the transmission & it'll pop itself up into the next gear, then then you're back on the gas. i do it both on the street & the track w/o much concern... haven't heard any reason to be concerned about it, sooo
    only reason you shouldn't do it 1st to 2nd is obviously because you've got Neutral in there. i made that mistake @ the last track day comin outta turn 12 & passing an sv1000... oops, hello 15k rpm's, g'bye SV
    Member nichols's Avatar
    Aug 2004
    Central MA
    Heh, I saw that. I was about a turn behind you guys, and saw you about to pass James. Here I thought you were doing your best at a Top Gun reenactment.
    '03 FZ-1 - the angry bumblebee.
    '84 KZ700 - the perpetual project.
    "Gonna hit the airbrakes & he'll fly right by!" At least i got him further down the straight... not bad for a little 6 hundred (and yeah, i know, i'm sure he wasn't goin balls to the wall )
    Manvile, RI
    Dec 2003
    Ma
    first gear?!?!?!?!?
    FIRST GEARR????
    cool, thanks guys.. same goes for downshifting?
    Originally posted by hessogood
    first gear?!?!?!?!?
    FIRST GEARR????
    Hey, the guy in front of the SV and I was RRREAAAALLLY SLOW through 11, 11a and 12, alright?
    yeah , but it takes some getting used to because you are doing the opposite and actually blipping the throttle to downshift without the clutch...practice
    takes a BUNCH more practice & it's worse if ya mess it up... most riders don't bother clutchess downshifting & just use the clutch.
    its good to do when your reaching for tokens or doing something with that hand ..like...picking you nose
    ah, si senor
    in that case i usually just wait till the RPM's drop to around 2-3k and just hit the shifter... i dont even bother w/ using any throttle to unload the tranny.... i thought you were talking in a higher RPM situation (track)
    You downshift at the track? when? when pullining into the pits? i just put it in 4th and keep it pinned
  1. involuntary clutchless downshifting practice
    By brady in forum General Bike Related
    Last Post: 08-31-15, 12:21 PM
  2. clutchless DOWNshifting
    Last Post: 06-03-15, 06:36 PM
  3. Clutchless Shifting
    Last Post: 02-09-12, 10:54 PM
  4. CLUTCHLESS UP SHIFTING is ok for your trany
    Last Post: 07-21-04, 09:14 AM
  5. clutchless upshift
    Last Post: 01-07-03, 04:37 PM
