Results 1 to 21 of 21
Compression Tester
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Compression Tester
    I'd like to replace my compression tester but not very keen on spending $100-200+ on an infrequently used tool.
    Was checking out this Lisle tester and the Pit Posse. For $40 on Amazon the Pit Posse seems like it might be the way to go.
    Any other recommendations?
    05GSXR75005SV65090DR350
    Re: Compression Tester
    I think I got mine at Autozone?
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Yeah, like less than $40ish seems right.
    Of course I don't know why you'd want to replace one.
    Just test the one you have. If it works, keep using it.
    Mar 2016
    Falmouth, ME
    Have an old HF one that I only used a handful of times, but tried on multiple running bikes and only ever hits 35-40psi.
    Lifer golden chicken's Avatar
    Attleboro, MA
    Try replacing the Schrader valve in the hose first. It should be the same as any tire valve stem.
    I like my OTC Deluxe. Can be had for $66ish, or the basic one for $55ish.
    You get better results if the bike isn't running
    The Schrader valve in the hose may be either hanging open or clogged with crud. They're a special low spring pressure design so the compression pushes it open. NOT a tire valve core.
    I use an OTC 5604, but they're closer to $95 than $40. No experience with the Pit Posse. Lisle is generally good, but the attached hose and extra purchase adapters are weird.
    *scooped by chicken while looking for the part number.
    yeah $40ish is what I spent too...just went on amazon and got the one with the best blend of reviews/price for the 2-smokah
    Lifer Falko's Avatar
    MoonTown
    I just put my thumb over the hole, if it pushes it off, good to go.
    Yeah, I bought one at autozone as well.
    I also have an OTC kit. And it works well.
    Be ware that for bikes you want the OTC 5604 kit Doug mentions. Not the OTC 5605, like I bought. The 05 kit has different adapters and doesn't work as well with deeply recessed plug holes.. like those you find on OHV engines.. which almost all motorcycles are. I make the 05 kit work, but get the 04 kit instead.
    I spent closer to $70.
    Calling BS. We all know you just rented it for a day.
    Mar 2016
    Falmouth, ME
    Well now you tell me, you know how hard it was to get that reading?
    That OTC looks like a nice little setup, a bit pricey but not terrible.
    I became suspicious of the Pit Posse when I noticed they sell my $10 Harbor Freight digital calipers for $35.
    i have a brand new, unused, INNOVA 3612 comp tester i can't use due to space issues on the RR. the adapter is too long, i can't fit it under frame.
    if you're interested, let me know. i'd be good with shipping + 2 bucks for a roadie in return (?)
    Mar 2016
    Falmouth, ME
    Actually I pulled the trigger on that OTC 5604. Looks pretty solid, exactly what I need, and hoping I'll have it in the toolkit for a lot of years.
    Thanks guys
    Put it in the go-kart and the next time you're blasting through at mach 1.5 along 195 stop in and I'll provide enough roadies to make your final approach questionable.
    Mar 2016
    Falmouth, ME
    wth is a roadie anyway? Asking for a friend
    Man I should have...used twice in 4 years
    Attleboro, MA
    I fix cars for a living and I've only used mine one more time than you have in the past 4 years.
    Mar 2016
    Falmouth, ME
    Satisfied! Nice little setup.
    Compression Tester
    totally missed this ... signal to ratio received
    Quote Originally Posted by Tekime View Post
    i could tell ya, but i'd have to supply ya. winkeroo.... .
    Mar 2016
    Falmouth, ME
    Hey, you shouldn’t eat Tide pods and drive man!
  1. Kal Heavy Duty Compression Tester
    By kumpy in forum Bike Maintenance
    Last Post: 09-12-12, 10:03 AM
  2. Replies: 7
    Last Post: 06-05-11, 06:14 PM
  3. Replies: 0
    Last Post: 06-05-11, 12:47 PM
  4. Leak down tester
    By KB in forum Bike Maintenance
    Last Post: 07-20-04, 03:51 PM
  5. Compression tester
    Last Post: 08-13-03, 09:00 AM
