I'm running a 2009 Ninja 250 and took off the fairings to do some general maintenance and cleaning. In doing so, I found my coolant to be extremely low and that I'm actually missing a few screws on the fairings.
Suggestions on the type of coolant I should purchase?
Does anyone happen to know the part number or size for the small "plastic plug screw things" (yup, technical, I know) which run under the fairing to hold the underneath of the fairing to the side? I'm also missing a large screw for the bottom on the fairing just before the kickstand and a screw along the radiator which holds the fairing in place there. I have the opposite side for both those screws so I can remove the opposite side if needed and bring to a motorcycle shop, but if I could order online and get it cheaper that would be great. Final missing screw is one in a bracket just to the left of the coolant tank and has a #7 on it.
Appreciate any thoughts and suggestions. I've looked on mrcycles.com, but unable to find the stupid things, although I did find my blinker enclosure, swing arm caps and air cleaner element.
