I just picked up a 1996 DR650 with only 3000 miles on it. It had been sitting in a barn for a couple of years. I had to give the carb a good cleaning before it would run, but it seems to run well now.
I have found that it has a fuel leak from the lower right hand seam of the tank (stock, steel). The seam is covered with a thin black moulding that I have yet to pull off. When looking into the tank, I can see some rust on the frame hump, but I have seen much worse.
I am looking for recommendations for repair. I have never used any liners, such as Kreem, POR-15, or Caswell's, but I have been told that it must be at least 60 degrees to use any of these (my garage is not heated).
I have also been considering Permatex fuel tank repair, which would possibly allow me to repair the tank from the outside without creating an eyesore.
The tank is beautiful, and does not have a scratch on it, so I would like to preserve it one way or another.
Thanks!
