Results 1 to 8 of 8
Back firing
    Just Registered Doc's Avatar
    Jericho, VT
    Backfiring
    Ok so the 1992 Ducati 900ss was running good, no problems with a stage 1 jet kit, K&N filter and my old beat to piss D&D pipes...
    So I get NEW D&D pipes, install them and now I have back firing, sounds cool at times but is getting annoying.
    I have my ideas, what are yours?
    .... duey's Avatar
    Wilmington MA
    Back firing
    does it only backfire under decel/engine braking? if it does the same thing happened to me, turned out to be an exhaust leak. Missing a copper plug on the bung on the exhaust pipe to be exact.
    2021 Ducati Panigale V2
    2020 Honda Grom
    Jericho, VT
    Back firing
    Yep only under decel/engine braking.
    Huh? a leak from the header or at the pipe/ slip on connection?
    .... duey's Avatar
    Wilmington MA
    Back firing
    I'm not 100% sure on what its called on the bike but on a car its considered a "bung" that usually the o2 sensor is located. I am told that that "plug" on our pipes is for dyno tuning which again is the same as a car since we use wideband o2 sensors to monitor air/fuel ratios to tune accordingly. Basically any type of exhaust leak will cause it to do that.
    2020 Honda Grom
    KB KB's Avatar
    Manchester NH
    Back firing
    New pipes may have more airflow/ less restrictive which is causing a lean condition on deceleration/closed throttle.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jericho, VT
    Back firing
    Ok so how do I fix it?
    KB KB's Avatar
    Manchester NH
    Back firing
    Carb'd or FI?
    I'm not the Ducati expert.
    Ok after just posting that and seeing it's a 92 I'm going to go with carb'd!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jericho, VT
    Back firing
    Yep Carbed,
    I guess I could turn the mixture screws out (in?) a lil...
    I don't think I need to rejet...
  1. Rear Cylinder firing off??? and RPM's slow to fall
    By jcbell1007 in forum Bike Maintenance
    Last Post: 07-16-09, 06:25 AM
  2. What the new R1 staggered-firing motor sounds like...
    By viva_brasil in forum General Bike Related
    Last Post: 12-10-08, 09:26 PM
