So here's the deal. I bought my wife a 91 Bandit GSF400. Needed motor work but everything was there and in really good condition other then faded paint. On to the engine... Nothing blown, nothing cracked, no thrown rods or anything... BUT it had sat for years with moisture in the cylinders. Well, they rusted. So, I pulled the engine apart and cleaned out the rust. It is freaking near impossible to get the stupid cylinders so I am hoping to save the one I have. Here's the gotcha.... I need to hone it a hair more to get it all hatched properly but I just put a bore guage to it....
Service limit is 56.080
In most parts I am fine and the bore specs in at 56.02... there is one section though where it is out of round and specs in just between 56.04 and 56.05 which is still well inside the 'out of round tolerance' limit of .2 and still .030mm within spec (Note, mm not inches... in inches that is .00118...).
So here is the gotcha.... the cylinders walls while mostly smooth, still have some ugliness going on. Normally I would hone this out myself with a stone, but I tried that and had miserable luck. I can have a machine shop do it for me on a professional machine but I am concerned they might get overzealous. I'm contemplating just using a ball hone and calling it good.
Anyone have any experience having this done at a machine shop when you are this close to the service limit? Anyone know anyone that can do a bore of .010mm - not inches - decently? I have a mill, it has that tight a tolerance but there is no way in hell I trust myself to attempt the job.
Thoughts, ideas?
