Results 1 to 6 of 6
dead PC3?
    Sep 2011
    Providence
    dead PC3?
    searched those terms but getting too many results, so I figured I'd ask: anyone ever had a Power Commander crap out?
    I was doing some maintenance on the bike over the winter, buttoned it up so I can ride tomorrow, went to fire it up but it wasn't cooperating, almost got it running on 1 cylinder, but it wouldn't stay running past few seconds, had no problems last time I rode it few weeks ago. Wasn't sure if it was something I did or ?? Checked everything I touched then unplugged PC3 and reconnected all the wires completely eliminating it, bike fired right up! (PC3 was installed before I even got the bike, never had any problems with it)
    Tomorrow forecast is 50's and I want to ride, don't want to spend all day testing this so I got it all buttoned up with PC completely eliminated, pretty sure it was the cause, just wanted to check if anyone had similar problem, or I will be tempted to plug it all back in again and test it....
    BTW, bike is 2007 Tuono (Rotax twin)
    Re: dead PC3?
    Yep. They aren't that reliable. They NEED a dedicated ground, right to the batteries -ve if possible, also. Sometimes they just lose their map and need it reloaded. I have seen at least 5 or 6 that have just crapped out and bike won't run.
    Re: dead PC3?
    Adrenaline cycle are your closest dynojet dealer. Not much they can do to test it, though. They work or they don't really.
    Sep 2011
    Providence
    Re: dead PC3?
    Yep, grounded to the battery, ran fine a month ago and then it didn't...
    Think I may have found a problem: pins on one of the injector plugs pulled out when I tried to sneak the PC harness out, wonder it that was a an original problem, but I didn't go near the injectors, replaced top triple clamp and fuel filter inside the tank, gonna plug it back in and test it... if I have time
    TWINS! xrocket21's Avatar
    Central Maine
    Re: dead PC3?
    you know... I havent looked at my RC51 since it died on me last fall, I wonder if its the PC3....
    Sep 2011
    Providence
    Re: dead PC3?
    don't look, just sell me the bike, CHEAP
  1. Better Ted, than dead!
    By Tabby in forum General Bike Related
    Last Post: 07-28-06, 01:19 PM
  2. It's dead Jim!
    Last Post: 12-01-04, 08:21 AM
