Results 1 to 4 of 4
Desperately need help with CBR elec issue.
    00 Cbr F4 00cbr_f4's Avatar
    Oct 2008
    Elab Umass
    Hey everybody I need some help tracking down an electrical problem on my 2000 CBR600 F4. So everything worked 3-4 weeks ago. But last weekend I pulled it out of my basement and none of the signals were working, the horn wouldn’t work, and the dash wouldn’t work but the headlight and the high-beam (and its light on the dash) worked. I also dont have the gas tank on yet so i dont know if the speedo will work or not. I’ve had it on a battery tender for a while amd though it was possible that the switch is just burnt up. Just swapped it no dice. I can’t hear the signal relay clicking when I try it… not sure how important that is. I put a new battery on it and check all the fuses and wiring and everything looks good. My Dad seems to think it’s a lose ground but I don’t know. Any help is appreciated.
    Re: Desperately need help with CBR elec issue.
    Did you listen to dad and check the ground wires?
    Oct 2008
    Elab Umass
    nope u know what it was... FUSE i must have checked it a hundred times. wasn't broken at all not a crack but put it to a voltmeter and it was a open circuit.
    Bullshit meter pegged scottfromboston's Avatar
    Oct 2009
    Maynard,MA
    Quote Originally Posted by 00cbr_f4 View Post
    Occam's Razor strikes again.....
    ~Scott
    2020 SMC-R
  1. Arc Vector: Stoopid Expensive Elec Motorcycle
    By FriskyDingo in forum General Bike Related
    Last Post: 01-10-22, 09:08 AM
  2. Replies: 3
    Last Post: 08-24-11, 06:22 AM
  3. Fender elec/acou 12 string $200 O.B.O
    By catahoulabuldog in forum For Sale
    Last Post: 06-01-11, 09:22 AM
