Results 1 to 18 of 18
dirtbike won't stay running
    ok, so I stalled the bike after it 12-o-clocked and I cut the throttle, and ever since then the XR80r won't stay running
    bear in mind the bike is warm: it will start just fine, but within 30 seconds or heavy throttle, it will stall
    if I try to start it right after it stalls, it won't start
    if I try to start it after a few mins, it will start just fine, then stall after 30 seconds
    I'm guessing it's not getting a constant flow of gas or it has a float issue. Should I take apart the carbs, soak/clean it with a carb cleaner, disassemble it and make sure all the parts are working, then (if necessary), replace the fuel filter?
    the gas switch is on "on", and I tried reserve
    what else could be wrong, and how can I fix it?
    Re: dirtbike won't stay running
    tap the carbs with a hammer not hard but you may have stuck the Float....if it sat prior to this this may also be a factor also...if it still does it rip it off and clean it.
    Dec 2003
    Ma
    +1
    +1
    + another 1
    live to ride seth399's Avatar
    Feb 2007
    CA
    +1 on that +1 on that other +1
    LRRS #399
    MX #505
    Meriden, Ct
    So this would be a +4???
    Dec 2005
    Near The Dragon
    i forget if that means bet heavy or wait a while..
    Get out while you can
    Find your own path
    Quote Originally Posted by Cerberus View Post
    table is HOT
    All strippers SHOULD have fake tits!
    Dec 2003
    Ma
    http://www.youtube.com/watch?v=ymwQ1XZsw60
    KB KB's Avatar
    Manchester NH
    I'm gonna +1 that plus up it one +1 and then raise you one +1, throw in a pack on gum and 2 envelopes.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Dec 2005
    Near The Dragon
    FOLD!
    Find your own path
    SLAM** DOMINO MUTHER FUCKER>>>
    ok, so I tapped the carbs with a rubber mallet and tried kick starting it again with the same results (stall after 10 seconds or so)
    I tried rapping it a little harder and got the same results
    So I tried rapping it while kickstarting it and I was able to get it to run for a little bit longer until it ran on its own. Then I put it in gear, rode it to the driveway, and it stalled.
    My guess is the tapping is breaking the float loose, but it's not seated in the correct position, or it gets stuck repeatedly
    any other suggestions before I pull off the carbs and start poking around?
    Sounds like you need to pull off the carb and start poking around
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Another possibility is that when you 12 o'clocked it you dislodged a bunch of sludge in the fuel tank and now you aren't getting any flow through the petcock. Thus it runs for a while but the engine dies of fuel starvation.
    I'd disconnect the fuel line and check that it flows OK into a jar before I pulled the carbs.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Quote Originally Posted by joeswamp View Post
    I checked the fuel line and it flowed pretty freely, thanks for the tip
    I then took apart the carb and found the pin that the float was hinged on was only seated on one side, so I slid it back into the other side and it works like normal again
    I spent a good 1-1/2 hours sliding around in the snow too
    thanks guys
    Good Deal......Nice pics and the Older XR'S are Bullet Proof....
    Feb 2007
    CA
    sweet, glad you got it going.
    LRRS #399
    MX #505
  1. Honda Generator Won't Stay Running
    By Puppet in forum Bike Maintenance
    Last Post: 12-11-23, 03:07 PM
  2. coolest bike ever doesn't stay running
    By wingerdor in forum Bike Maintenance
    Last Post: 09-27-10, 05:52 PM
  3. Stay Down...
    By DucDave in forum Pit Area
    Last Post: 07-04-10, 09:19 AM
  4. Replies: 62
    Last Post: 11-14-08, 11:53 PM
