I put my front rim back on and now there is a what seems like alot of drag but I know tha brakes are not binding.
Help
http://www.facebook.com/#/profile.ph...&id=1185417660
Live life now!....it has an expiration date!
Friendship is like peeing in your pants,
Everyone can see it,
But only you can feel the true warmth.
did you clean and regrease the axle? Maybe some dirt or debris got on it.![]()
Zip Tie Alley #237
cleaned it and put a little grease on it so I didn't gawl it. I guess it really was evident when I tighten the axle as if there was to much force squeezing the axle on the bearing collars.
Make sure you put the spacer in. Look around in your garage.
Bruce
Ive got the spacers in.
I know on my bike I can put my rim on either way, is your tread heading the right way??????? Don't know what it does when tread goes wrong way but maybe?? anyone..
<div style="width:160px;border:1px solid #036;padding:5px;text-align:center;"><a href="http://www.myyearbook.com/?me=AzUFa1czXWRWZgJnADkCPA==" target="_blank"><img src="http://assets.myyearbook.com/logo_blue_blog.gif" width="146" height="38" style="border-width:0px"></a><br><a href="http://www.myyearbook.com/?me=AzUFa1czXWRWZgJnADkCPA==" target="_blank" style="color:#036;font-family:Arial,Helvetica,sans-serif;font-size:15px;font-weight:bold;">Sign My Yearbook!</a></div
Yup tread is headed the right way.
The wheel was off for about a week and a half, would something have dried out?
Or do you think the shop I went to fucked something up?
I would say take the wheel off and inspect the bearings as best you can without taking them out, What did you have the shop do to it? anything that would effect the bearings? Brakes are not dragging right?
Try reinstalling your wheel but while it is off, pry back your brake pads to see if that has anything to do with it.
Does your axle just get torqued down or is there a pinch of on it? If there is a pinch bolt then it only needs to be torqued to a small ft/lb generally
Edit: this is google for you
Front brake caliper bolts: 22 ft lb (and a dab of red locktite)
Front axle pinch bolts: 16 ft lb
Front axle bolt: 58 ft lb
Rear axle nut: 83 ft lb
You do have a torque wrench right Mr. engineer?
I'm all set, I never notice the drag before I changed tires, but it appears that the last dlido to put brake fluid in put way to much, so the calipers wouldn't release. Drained a little last yesterday to get it down to the upper level and everything is O-Tay!
