Changing the front brake lines on the GSXR750 to SS braided lines. Got the style that goes from a banjo at the master cylinder to each caliper.
What is the best way to drain the brake fluid? I think shops pressurize the master cylinder but not sure I could make that work.
Seems if you remove both ends everything leaks out, so that seems sub-optimal.
