Results 1 to 22 of 22
Drivechain...
    crash squid elaineo's Avatar
    Oct 2003
    Drivechain...
    This is probably a stupid question, but my chain rattles when I spin the rear tire. I checked the tension and it's taut as it should be, but for some reason it is rattling and didn't do that before I left it sitting for a few months. I cleaned/lubed it before putting the bike away. Is this a normal thing for a chain to do?
    Newbie
    Mar 2004
    Drivechain...
    I would spin the wheel and be sure its not rubbing on anything. Like the chain guard. Also take a look at the connecting pin and be sure its on their correctly. Its probably normal friction noise.
    Hope that helps.
    Lifer legalspeed's Avatar
    Somersworth, NH
    Drivechain...
    Check your alignment.
    Is your bike on a rear stand?
    LRRS\CCS\WERA #486
    Walpole
    Drivechain...
    Be more specific on the sound if you can.
    Is it a rattle or more like a clicking or binding sound ?
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Drivechain...
    a "taut" chain is NOT what you want. A loose chain is a happy chain. Not to the point it's falling off but allow the suspension to work. A good way to check if it's too loose is to try and pull the chain off the back sprocket from directly behind the bike. I do not follow mfg. recommendations for adjusting chain slack. As for your problem, I don't know what kind of rattle you mean, but you may be hearing the chain guide tapping the swingarm when the chain moves. Not abnormal but make sure the mounting tabs are ok.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Oct 2003
    Drivechain...
    it's on a centerstand.
    The rattle is actually both, it clicks and also makes a, um, noise
    Oct 2003
    Drivechain...
    Come to think of it, the chain might be too taut. When I pull down on it it'll only give about 10 mm at most. So I'm supposed to be able to pull it off the back sprocket? ok.... i'll try adjusting it....
    Walpole
    Drivechain...
    Your chain isnt too bad where it is now because I think it is just binding up from lack of lube under those o-rings. If that is the case you wont get a proper chain tension check either.
    2000 Ducati 900ss
    Oct 2003
    Drivechain...
    thanks pin head i'll lube it up if i can find my fucking chain wax
    NOT laughing with you {~; bemused's Avatar
    Deer Island, OR
    Drivechain...
    I have it on good authority that they're still sellin' the stuff...
    (in fact, I now have 2 semi-full cans for that very reason... )
    jeff f
    '97 RF900R
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Drivechain...
    No, your not supposed to be able to pull it off the sprocket, that is a sign you went too far loosening it. Lube the chain up really well. Play with the adjusters a bit. You will see the chain giving a little as you turn them in. I do it by feel now.....but use the sprocket check as a gauge. You have to really give the chain a tug off the sprocket.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Everybody to the limit!
    Winchester, MA
    Drivechain...
    You wanna borrow my EX500 clymer manual? It talks about stuff like chain adjustment and such, should be helpful for the EX250 too. Remind me next time I see you, I'll bring it, I don't use it much anymore anyway.
    Oct 2003
    Drivechain...
    thanks . now maybe i will decide not to kill you for your earlier comment
    Oct 2003
    Drivechain...
    Winchester, MA
    Drivechain...
    Mrphrmrmmmrph grphrmmrphrml...
    It's hard to talk with this foot in my mouth all the time
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    Chain tension
    Maybe this is (stretched) TOO FAR?
    Suf Daddy.
    Mar 2004
    Foxboro
    Drivechain...
    How old is the chain? Under extreme circumstances of wear, I've seen the rollers (the actual part that contacts the sprockets) become very loose on the chain pivot pins. It can be very noisy no matter how much lube is on it or if its adjusted properly. Also, if the chain is in that poor of a condition, the sprockets are probably not too good as well.
    Somersworth, NH
    Drivechain...
    Tighten and losen all you want, if your rear wheel is not aligned, the drive chain will "click" around the front sprocket.
    Proper chain tension: the chain should have a little play when the swing arm is rotated to the max tension position. On a center stand, put a lever under the rear wheel and lift. As swing arm straightens, you will see the chain come under tension.
    If there is no play at max tension, you will destroy; bearings, sprockets, chain, and yourself as the suspension can no longer do it's job.
    I think you need an experienced eye to help the first time.
    DISCLAIMER: I'm not really good at this, but I've seen good suspension people demonstrate the above.
    -D
    LRRS\CCS\WERA #486
    KB KB's Avatar
    Manchester NH
    Drivechain...
    One last thing to consider and this happens all the time is that the stand may be hitting the sprocket bolts making a clicking noise. Well not actually the stand but the doomaflaggy thingamajig that goes under the swingarm.
    Jus my 2 pennies. Cuz It's happened to me!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    KB KB's Avatar
    Manchester NH
    Drivechain...
    Funny you say that KMF. I had a chain installed by a motorcycle shop in Machester that sells honda and is located on Second st, well I was a new b and didn't know any better, anyways, they riveteed the master link too tight. After about 1000 miles the rollers had become loose from the initial extra binding.
    It was making a racket cuz that part was loose on the sprocket and trying to ride up over the top of the sprocket spannig 3 teeth, I did just that. I went out and got some master links, bought a chain tool, hacked a part an old chain from a buddy, replace above mentions bad links with 2 masters and wallah.
    Now I do my own chains right the first time.
    KMF.........I put up a fork oil change post help a brother out with you knowledge. You def. know what you speak of
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Mar 2004
    Foxboro
    Drivechain...
    KMF, my whole chain is made up from master links, so when i hear noise, i can replace just the bad part without cutting the chain. It did cost me about $500 bucks to build it but it was well worth it.
    Walpole
    Drivechain...
    Damn ! My banshee allready has 3 of them, only 101 more links to get
    I'll have ta add those to my order J
    2000 Ducati 900ss
