Results 1 to 12 of 12
husky 701 turn signals (brain teaser?)
    Feb 2011
    Somerville MA
    The signals on my 701 Enduro work OK when I first get on the bike, and for maybe another 5 minutes. For reasons unknown (heat? vibration? chemtrails?) they get weird soon thereafter and totally inoperative soon after that.
    Euro bike character fer dayz!
    I have an appointment at the dealer 6/22 but would prefer to pass an inspection before then. Ideas?
    The 701s are notorious for roasting rear-left signals due to the pipe exit point and lean stock mixture, but a) mine has a heat shield on that signal housing, and b) I've seen signal function come back near the end of an in-town commute before, so I'm sort of leaning toward a vibration/loose connector issue someplace.
    -Jared
    Lifer Falko's Avatar
    MoonTown
    Re: husky 701 turn signals (brain teaser?)
    Some euro bikes are notorious for undersizing wiring and electrical components. The flash relay (if such the animal is present) might be undersized and overheating. Have you tried different lamps? Maybe LEDs which have lower wattage.
    Feb 2011
    Somerville MA
    I haven't tried any changes at all, yet. Since I first noticed the problem I've mainly just been paying a little more attention to it, trying to get my head around the symptoms. I'll likely take the headlight assembly off tomorrow evening so I can get a better look at the wiring between the dash module and peripheral bits.
    Aside:
    One nifty feature of the spartan-looking dash is native support for adjusting the speedo for different wheel sizes. If you disconnect the headlights, you can go to the normal dash setup and set the front wheel circumference in millimeters. Super handy once my SM wheels arrive.
    -Jared
    Lifer golden chicken's Avatar
    Attleboro, MA
    I like this theory. If the flasher uses a bimetallic strip, and it is in a hot location, it may never cool enough to close the circuit to give you the flash.
    Feb 2011
    Somerville MA
    According to the warranty service tech, it was a loose connector. Time will tell.
    In other news:
    That pic is helping me understand why people do sumo beak replacements, but I’m all the way down with how the anodizing came out on the hubs.
    -Jared
    Doooooooooooooooo waaaaaaant!
    Your the guy that gets stuff stolen all the time? Please lock that thing all the way up.
    Sumo fenders are overrated. Nothing quite as epic as rolling down the front straight of your favorite race track in a tuck, watching the speedometer tick higher and higher, then noticing your fender flapping in the breeze like an elephant in a mosh pit high on speed.
    Feb 2011
    Somerville MA
    Not for a while now, but yes. And I will. It had the 600mi service at the same appointment, so I may finally let the wrist do as it wants.
    Haha fair enough. I look forward to getting it to flap its big goofy trunk around.
    -Jared
    Feb 2011
    Somerville MA
    Anyone got a link to a primer on how ABS sensors/rings are meant to interact? ABS light stays solid on after the wheel swap, despite presence of ABS rings on the new hubs.
    -Jared
    Feb 2011
    Somerville MA
    The gap between the sensor and the ring looks really close in the front and not so much in the rear.
    Haven’t tried recalibrating speedo to new wheel circumference yet; not sure it should matter but would make some sense if so.
    -Jared
    Attleboro, MA
    There should be a spec somewhere for the correct air gap. There should be a gap. It should not be touching.
    Feb 2011
    Somerville MA
    Thanks GC. After recalibrating the speedo, the ABS doesn't fault until I hit 55mph or so, but faults consistently upon reaching highway speed. I looked up the ABS module part numbers for the 701 enduro vs. supermoto (thinking maybe the SM one had a different 'magic ratio' of expected front vs. rear turn rate burned in) but a) the part numbers are the same, and b) the list price for the ABS module was $4k with 'discount' down to $2.7k. Who knows if that's actually what a replacement would cost through a dealer, but at least now I'm not tempted to fuck with it.
    Another option is to try the 'ABS dongle' to enable front-only ABS. If it makes the ABS module stop caring about whether the rear wheel locks, maybe that not-caring would carry over to fixing my fault somehow? Seems a little thin, but only costs $100 to find out, and front-only ABS sounds like it could be a good time anyway.
    -Jared
    Feb 2011
    Somerville MA
    Guessing these parts are identical:
    2017 KTM 690 Enduro R ABS dongle
    60312953000
    2017 Husqvarna 701 ABS dongle
    27012953000
    -Jared
  1. Wireless turn signals?
    By whynot in forum General Bike Related
    Last Post: 07-30-19, 11:32 AM
  2. OEM CBR turn signals to give away?
    By akira700 in forum Wanted
    Last Post: 10-03-12, 09:33 AM
  3. WTB: 04-05 GSXR600/750 OEM Turn Signals
    By senecak19 in forum For Sale
    Last Post: 06-22-08, 04:15 PM
  4. Custom turn signals
    By snaggle in forum General Bike Related
    Last Post: 04-02-02, 07:10 PM
