I did a valve adjustment and took it for a ride. Everything ran fine. The next day I replaced the fuel filter as it was having an existing issue of running to redline at full throttle. It would rev up fine at full throttle up until 6500rpm then fall on its face and not be able to increase the RPM. So I replaced the fuel filter. There was an aftermarket filter in there. The little wire (grounding?) was attached to the metal body of the filter with a hose clam since that filter didn’t have a little tab for it. I put in the new OEM filter and attached the little wire snugly with stainless safety wire to where it belongs. What is this little wire for?
I put everything back together and it wouldn’t start. It would just crank and crank. Occasionally it would fire up for 1 revolution, but then go back to cranking. I primed the fuel pump a few times and same thing. I pulled the spark plugs and it was a little damp. I dried it off and reinstalled. Same thing. I detached the outlet hose of the fuel pump flange, turned on ignition and confirmed fuel does in fact flow.
Next day I took the fuel pump assembly back out, confirmed everything was still in place. Also removed the hoses that attach to the fuel filter, blew through it and confirmed that it was not clogged and that it was installed in the right direction. Put the assembly back in and unplugged the wiring for it. I pulled the spark plugs again, and with the plug wire still attached, grounded it to the exhaust pipe and crank it and I could see visible blue sparks as it fired. I used the engine turning tool and set horizontal cylinder at TDC from the flywheel side, then confirmed that the timing marks were aligned at the pulley side. Put everything back together and attempted to start again. This time the engine seemed to be able to fire up for a few more revs then die. I was able to keep the engine running by adding a little input at the throttle. When it did run it ran really rough and didn’t sound good. If I gave it more throttle than say 15%, it would die out. Also, if I give it too much throttle as it cranks, it would make a loud pop and puff something out of the air filter through the open lid.
I’m stomped at what the issue could be. What should I test next? I have read that it could be a TPS. I have a multimeter. How do I test the TPS?
To sum it up:
•Has fuel
•Has spark
•Has compression
•Good timing
Whats next?
