Results 1 to 20 of 20
Rotary vs Linear Steering Dampers
    Windham NH
    Anybody have any experience using both types at different times on the same bike? I've been waiting for a used Scotts damper to appear for a while now but dont want to wait any longer. Considering buying a $30 ebay GSXR damper and mounting it to the lower triple. $475 is a lot of dough for a new Scotts setup.
    Re: Rotary vs Linear Steering Dampers
    Is this for a track bike or street bike?
    I think they do the same job adequately. It really comes down to the mounting solution, as the rotary damper is less cumbersome than a linear damper, especially if the bike doesn't come from the factory with a damper.
    I've used a Scotts rotary and an Ohlins linear on my 1st gen SV. They're both good at what they do. I didn't notice a difference one way or the other in function.
    As for preference, I like the linear, because you don't have to remove the damper to remove the tank. On a 1st gen SV, that's a good thing, since part of my off-season maintenance is to clean the carbs and that requires the removal of a rotary damper and tank. I haven't touched the linear since installing it at the beginning of last season. Installation was easy with a GSX-R front end and an aftermarket bracket.
    AMA wannabe lrrs699's Avatar
    RI,NH, Derby,ct
    linear
    LRRS Expert #99
    08 R6
    "why tip-toe through life to arrive safely at death?" Tony Campol
    To quote PK, I "went in too hot and ran out of talent".
    who knows
    they both suck, use your arms, best steering dampers out there...
    Windham NH
    Quote Originally Posted by Lxpony View Post
    Track.
    Sounds like I'm going to go the cheap way. Awesome!
    linear.
    if you're using a stock GSXR damper, drain the oil out of it and fill it with heavier fork oil. it's a cheap way to make your damper a little stiffer
    Haverhill, MA
    I don't know your particular application but some of the original reasons people went with the rotary over the linear was the ability to place the rotary unit in a location that is far less susceptible to crash damage. In your case the linear may also install in a location where it will not be damaged in a crash but if not it is something to consider.
    On an 03 SV, a linear would mount in front of the lower triple, so it is less likely to be damaged in a crash than a tank-mounted linear or rotary would be.
    I have no problem removing the tank on my gen-1 SV without removing the Scotts rotary damper. All I do is remove the mount assembly.. which is mounted with the two bolts that secure the front of the tank anyway. Can't imagine how one damages the rotary in a crash. It is mounted on top of the top triple well inboard of about eleventy billion other bits. If it gets wrecked, the rest of the bike has to be really fubar'ed.
    that is what got you into the tank slaper in the first place
    Some orgs (WERA) require them now.
    who knows
    I honestly had nothing to add so I was merely making a joke, I've never had a tank slapper but I have a Scott's rotary type on my CBR so I wont.
    Senior Member Viper897's Avatar
    Apr 2014
    Seacoast Maine
    Rotary, I have a scotts on my gen 2, and will be getting the bracket for the gen 1 so i can swap between bikes.
    Like some have said though, if you have the gsxr front end then a linear may be the way to go.
    Just my .02 cents.
    I know.
    Aug 2009
    Hillsborough County, NH
    I had a rotary GPR V.3 stabilizer on my 2001 CBR 929rr. I thought that fit and function were great. Easy to remove (two hex bolts) when I need access under the fuel tank. I can not speak for the linear style dampers. I have read that the OEM Öhlins dampers that come with the (09-12 ZX6r) are basically useless and need to be sent out for a re-valve job in order to be effective. I can not speak for the GSXR that is in question. If you buy it I would plan on having the oil and seals replaced, possibly a re-valve.
    🇯🇵 2001 Honda CBR 929RR R.I.P
    🇯🇵 2009 Honda CRF 250X
    🇯🇵 2013 Kawasaki Ninja ZX636R
    🇦🇹 2016 KTM 1190 Adventure-S
    Windham NH
    I went for a $15 05-06 GSXR damper. Going to try it with 15wt fork oil and see how that works. Really just looking for help in 7-8 and 10-11 at NHMS.
    pretty sure i used 20w on mine
    Pete, if you still have my digits call me.
  1. Steering Dampers
    By Rosco61 in forum General Bike Related
    Last Post: 02-10-13, 01:33 PM
  2. GSX-R OEM steering dampers
    By Jim in forum Bike Maintenance
    Last Post: 08-19-12, 09:41 AM
  3. Steering Dampers
    By wortown03 in forum General Bike Related
    Last Post: 11-26-07, 10:32 AM
  4. Steering dampers?
    By gixxer6 in forum Dirty Bastards
    Last Post: 10-06-04, 07:04 PM
  5. HYPERPRO ACTIVE CONTROL DAMPERS or SCOTTS ROTARY STEERING DAMPER
    By greco954 in forum General Bike Related
    Last Post: 06-28-04, 04:00 PM
