Ok guys, so i pulled the zx9 out of the garage last week. I didnt put any stabil in it this year(i know i know) so it was running a little crappy, wanted to stall when getting rolling from a stop. So i'm thinking to myself "ok i knew i was gonna have to go through the carbs this year, no problem". Until I leave one stop light and all of a sudden i have no power, the bike doesnt wanna go anywhere and i have to putt putt over to the shoulder.
At this point im thinking "fuck, probably fouled the plugs" except it would start and idle just fine, but sounded like it wanted to stall and had no power under a load. So i get the pickup and bring the bike home drain the tank and get to work on the carbs, theyre dirty but not awful, so i go through them and clean them all out no problem. Air filter looks fine. I pull the coil packs and plugs and the plugs dont look fantastic but they dont look bad either, so I clean them up with some sandpaper and put them back in. Reassemble everything, fill the tank with fresh gas and a lil bit of injector/carb cleaner mix fire it up and its running just fine, idles fine, real smooth from a stop, I'm thinking its all better.
Today I take it for about a 20 min ride, fairly spirited, getting the rpms up there. Stopped and shut it down for about 10-15 mins while i got a haircut. Came back out after, tried to start it and all it did was crank, wouldnt turn over, but could smell the gas in the exhaust so i know its getting fuel. I let it sit for a few more mins so i wouldnt flood it, then tried cranking again, and on the third try it turned over like nothing ever happened, idled and rode home just fine.
I'm assuming this must be something electrical and I dont know anything about anything electronic. I went and picked up new plugs today just to try the cheapest solution first but that doesnt seem like it will be the solution. A friend suggested some kind of relay issue?
im just not really sure where to look
