1
In the past I’ve ordered the oddball Japanese electrical connectors needed for accessories from Eastern Beaver, a Canadian living in Japan. He made some special harnesses for Bikes like VStrom (a relay so the starter switch didn’t burn out, and one to shut off one headlight so you could run a toaster) and has all the widgets. Super helpful guy.
https://www.easternbeaver.com/
But for my wife’s CB500F I needed a particular connector as the harness I was using from the CB500X is different from the accessory terminal on the F.
The owner of Cycle Terminal Joe Scavone identified the connector needed from a not very good picture, and sent it out next day. Also ordered the terminal tool to extract the terminals as couldn’t find anything small enough to work.
http://www.cycleterminal.com/motorcycle-connectors.html
And he has a guide to removing terminals that’s very useful.
http://www.cycleterminal.com/termina...procedure.html
