Results 1 to 11 of 11
Electrical Issue
    Lifer obsolete's Avatar
    Norf Sho
    Electrical Issue
    For the last month of riding last year and continued into this season I've had a weird gremlin where my headlights would turn off and the blinkers would turn on. Riding for a while and it would go back to normal. I went looking for it today by giggling wires and found it up front behind the speedo. So I have it kinda narrowed down but I noticed the black wire is hot and the connector is burned around that pin. The connector stays hot even when everything is working normally. When I say hot I mean burn you hot and around the connecter pin is brown/black charred. So I don't know if the hot wire is back feeding the system or the blinkers and headlight are crossing. I don't really feel confident in my electrical skills to leave it on to figure it out due to the heat. Any electrical gurus wanna fix this for what ever you charge?
    -Alex
    Derry NH
    Re: Electrical Issue
    You free this weekend? I can stop by and take a peak. 12 volt electrical is what I do for a living.
    Littleton, Ma
    i am willing to help if you want to swing by my garage alex.
    Norf Sho
    Luckily I ran into Mark(TLRman) in Newburyport and he said it's fairly common that the connector in question burns out cause it can't handle the amps. I'm gonna jump it out and make sure it's all good.
    -Alex
    Just Registered drop's Avatar
    Bradford, MA
    text me if you need help, i'm a few min away and it's really just a good excuse to drink beers in the garage.
    - Jamie
    2009 K 1300 S
    Norf Sho
    You can drink beers in the garage whenever you want.
    -Alex
    Haverhill, MA
    tlzone.net is a good place to look for information on this problem. All the TLs had similar issues and I can only assume that the same mods that fix it on the TL would likely fix it on the SV.
    Joel
    Norf Sho
    I'll take a look, thanks Joel!
    -Alex
    Norf Sho
    After looking at the fix my burnt connector is different than the one that people have a problem with. Hmmmm...
    -Alex
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Lots of amps plus too much resistance = heat. Which can result in increased resistance, leading to more heat, etc.
    The first thing to do here would be to clean the connector thoroughly and reassemble with some dielectric grease.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Norf Sho
    Solved. Jumped the connector and no more heat. Kinda relieved that the shirt was just in the connector.
    -Alex
  1. Electrical Help: KTM
    By iTGbuDeeV in forum Dirty Bastards
    Last Post: 05-22-18, 07:24 PM
  2. HELP: CBR Electrical issue
    By DankDirtyBird in forum General Bike Related
    Last Post: 05-26-11, 10:15 AM
  3. Need electrical help!
    By akira700 in forum Bike Maintenance
    Last Post: 04-09-09, 02:50 PM
  4. Aprilia/electrical guru's... issue w/ the T.
    Last Post: 10-28-08, 01:54 PM
