Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Ex500 issues
    Seacoast NH
    Re: Ex500 issues
    It sounds like you have a vacuum leak.
    Just to throw more fuel on the fire.. have you checked the valves?
    Member Johnpewpew's Avatar
    Aug 2017
    Chicopee, MA
    Re: Ex500 issues
    No not yet
    2016 triumph street triple R
    "A Journey must begin with one step"
    Seacoast NH
    Re: Ex500 issues
    I'd add a valve check to your short list of things to do to that machine. If you find tight valves on one cylinder it might explain some of this. Maybe.
    Anecdotally : I acquired an SV650 (also a twin) recently that had the valves timed 180-degrees out of phase. Both cylinders were set to open intakes, exhausts, and make power, etc on the same stroke. Made for a very strange running behavior. Idled like shit, came into power mid-band and then tapped out early (even for an SV).
    Not saying this is your issue as you have a cold header. Just saying it may be worth your time to check the valves and timing. I swore I had one jug not firing too and it turned out to be valve timing instead.
    Re: Ex500 issues
    Look at mister Moto GP Big Bang SV in here!
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Seacoast NH
    Re: Ex500 issues
    Usually only the ladies call me that..
    Aug 2017
    Chicopee, MA
    Re: Ex500 issues
    Ok so compression test complete both cylinders are running on the low side but still within spec. And the cylinder in question has slightly higher compression than the good cylinder.
    Aug 2017
    Chicopee, MA
    Re: Ex500 issues
    Well I took it out for a spin the the highway. And she ran pretty good. A slight hesitation around 9k. Other than that and me running out of gas...... (Ya I know) she seamed to do good. Now I've never ridden a good running he acts before so I have nothing to compare it to. I'm going to load it up on the truck and take it to the track of me Sunday when I come to watch and meet you guys. Then you guys want to help me and give it a once-over that be greatly appreciated.
    Re: Ex500 issues
    Quote Originally Posted by Johnpewpew View Post
    Which day are you coming up? I'll be up there Saturday. Can introduce you to bj.
    Aug 2017
    Chicopee, MA
    Re: Ex500 issues
    I'll be up Saturday. That would be great I've already talked to him on Facebook about a belly pan.
    Senior Member Philkinson's Avatar
    Jun 2012
    Warwick, RI
    Re: Ex500 issues
    Giggity
    Sent from my SM-G920T using Tapatalk
    now retired LLRS AM #642
    Re: Ex500 issues
    Quote Originally Posted by Philkinson View Post
    Giggity
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Re: Ex500 issues
    Don't let smutty near it. He'll rub his nuts on it.
    Branford CT
    Re: Ex500 issues
    That's a right of passage
    Aug 2017
    Chicopee, MA
    Re: Ex500 issues
    so i went up on Saturday. the ex crew got it running right. looks like i fucked up putting the carbs back together shes running great and September is looking like a go
    5 Not allowed! Not allowed!
    Re: Ex500 issues
    BJ, Joe, and the other guy I don't know FTW.
    Nice to meet you dude!
    Aug 2017
    Chicopee, MA
    Re: Ex500 issues
    Ya they deffinaltly helped out.
    Nice to meet you to. I'll be there in September
    Re: Ex500 issues
    But how exactly did you fuck up. THat is what we came here for.
    Aug 2017
    Chicopee, MA
    Re: Ex500 issues
    I didint clock the dohicky in the slot.
    Lifer Pittenger5's Avatar
    Austin
    Re: Ex500 issues
    You all laugh, but the dohicky is a legitimate part on an EX500.
    Zip Tie Alley #505
