Results 1 to 25 of 25
exhaust flange bolts
    Evil Twin Ryder KillahTillah's Avatar
    Dec 2005
    Fall River
    look what i did...i sheered off the lower bolt on the exhaust flange...wtf... what can i do now....don't have enought clearance to remove rear exhaust so is my only option to remove the other exhaust system? anyone have problems with the flange bolts on the head on the front of the engine???...please help and thank you....it's 2002 suzuki TL1000R...
    Attached Thumbnails Attached Thumbnails exhaust flange bolts-img_20130424_123638_242-jpg
    If it ain't Fun, You ain't Rydin.....
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: exhaust flange bolts
    Post a pic of the other side of the bolt..
    High maintenance priss
    Central MA
    I have sheared a bolt head on the front cyl exhaust flange on the TLR; don't go at it ham-fisted. Hit it with some heat, PB, alternate CW/CCW & impact to help free the bolt.
    Lifer JohnnyV's Avatar
    Westborough, MA
    If I remember correctly Degsy has tackled this issue before.... common on TL's
    EDIT: Nevermind, thought you meant you sheared off the stud at the cylinder
    Jun 2005
    Is that a nut on the other side? Can it just get PB blasted and then punched out toward the nut side or is there not enough room?
    Dec 2005
    Fall River
    will try to post a pic for all on the other side of flange is a welded nut
    Jun 2005
    Ah, it's welded.... If you have enough room for a center punch and a drill it looks like you've got a nice flat surface to start drilling on that bolt (I use left handed drill bits and heat on stuck bolts... Sometimes the bit grabs and turns the bolt out).
    Dec 2005
    Fall River
    yeah can't get a clear shot...i tried using a punch a realized i can do it with removing the left side exhaust....Might as well just do it right...just fear snapping the bolt on the front flange on the head....lol
    exhaust flange bolts-img_20130424_132856_636-jpg
    Jun 2005
    Might want to get in there with some PB blaster and let it soak for an hour or two first.
    Dec 2005
    Fall River
    yeah gonnah have to work it.....and pray
    Jun 2005
    Don't forget the anti-sieze when you put it back together.
    Dec 2005
    Fall River
    exhaust flange bolts-exhaust-flange-jpg before
    exhaust flange bolts-flange-bolt-jpg after
    exhaust flange bolts-head-flange-jpg had to take the dreaded exhaust header bolts...
    Dec 2005
    Fall River
    it's going to need to be tapped....anyone have the skillz.....i have never done it...
    Tap a hole? Anyone can. (I can, so really anyone can. )
    But really, don't you just want to chase it?
    Dec 2005
    Fall River
    whats that??...not familiar with this ...?
    Buy one of these in correct size:
    Lubricate, maybe with some of this:
    Stick in hole.
    Turn.
    Repeat as necessary.
    Banned G21forme's Avatar
    Lakes
    Turn back out, turn back out, repeat as necessary if you have patience it works the balls. Saved my bacon once or twice.
    Dec 2005
    Fall River
    oh boy do I have patience I will get right on it...
    Dec 2005
    Fall River
    Stick in hole.
    Turn.
    so i should try with my current size bolt and upsize if necessary?
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    current bolt size, that steel is hard. Did you get the broken bolt out?
    Just finished building a TL, and I still have another. I know these bike very well.
    Nov 2010
    Warwick, RI
    And use cutting oil, so much better than WD. I have a tap set if you want to borrow it, I'll be in Hudson, Ma working in my garage this weekend. Or just bring the piece over.
    Dec 2005
    Fall River
    yeah here it is.....don't know how the fuck those threads got fucked up like that.....but you know then that it's just a nut welded to the flange that holds these bolts in....this is the flange that connects the left and right exhaust....
    Nov 2010
    Warwick, RI
    Overtightening, no use of washers, no anti-sieze, electrolysis, and a combination of all of the above. replace those exhaust gaskets, they pop right out. I have 2 new ones if you need some.
    Dec 2005
    Fall River
    Quote Originally Posted by jbmass View Post
    yeah i have that gasket Thanks ...and i was initially replacing the damn rear cylinder donut gasket it was half gone...so i counted on replacing the flange gasket ....but i had to take the whole left side off to get this right side out to free the frozen bolt.....it sucked...so all new gaskets and bolts have been ordered...lol
    Dec 2005
    Fall River
    Damn i never finished this thread......got all caught up when i had to re-thread the damn oil drain plug....Thanks for all your help JBmass i can't thank you enough bud.....one day i will come back to yah....Thanks
  1. For Sale - Parts & Tools | Lightly Used Rinehart Exhaust & Stock Exhaust 2020 Street Glide
    Last Post: 01-03-21, 03:09 PM
  2. Welding broken exhaust bolts
    By Tekime in forum Bike Maintenance
    Last Post: 02-26-18, 11:39 AM
  3. Rotor bolts?
    By Femmekat in forum General Bike Related
    Last Post: 02-24-10, 12:27 PM
  4. bolts
    By Wishbone in forum General Bike Related
    Last Post: 03-29-07, 09:38 PM
