Results 1 to 5 of 5
Anyone Have Experiance With Weak Charging System On Their TLR
    Junior Member tiller's Avatar
    Oct 2002
    Rocky Hill, CT
    I have recently replaced the battery, rectifier and stator and I am still having issues with weak charging. I have heard that there can be problems with the wiring harness in general, does anyone have any experiance with this on TLs
    tiller
    LRRS# 415
    www.onedownfiveup.com
    Haverhill, MA
    Got the same problem on my TL. The only thing I have seen is the same thing you mentioned that the wiring harnesses are not so well put together on our bikes. I have yet to pull mine apart and fix all the connection points, maybe next winter for something to do.
    Have you checked out tlzone.net (formerly tlplanet)? There are a ton of TL owners over there that have a wealth of knowledge about the bike.
    L8R
    Joel
    Wish I could chime in with something helpful here. TL's in general (S's & R's both) seem to be afflicted with this. My battery only lasted 3 years. From what I've been learning, I'm not in the minority...
    Alfred put a manual light switch on his that turns the headlight OFF all together. Pretty slick...
    Oct 2002
    Rocky Hill, CT
    well I have since found out that it had nothing to do with the lights and while the lights do draw a decent amount of power from the system it still should have been some what close, the replacement stator I had put in was bad when tested I was only getting 40VAC across each leg of the stator so no more aftermarket stuff for me when it comes to charging systems, I replaced that one with an OEM one I purchased from RonAyers.com and I also swapped out the stock power and ground cables with something a bit heavier gauge, when tested I was getting slightly better results than what the service manual quoted so I am happy again.
    I appreciate everyone trying to help and put there two cents in, dont have a whole lot of twin owners out where I am let alone TL owners, thanks guys.
    tiller
    LRRS# 415
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    same here just replaced my battery
    i put a fresh when i got mine so im on my 2nd .
    turning the light off will help when it's warming up you taking & not giving back .till about 4000 rpms .
    the way ive seen you beat on that bike im not suprized
    www.bostonmoto.com
    Forum Rules
  1. How do I determine if I'm over-taxing my battery/charging system?
    By jeantarrou in forum General Bike Related
    Last Post: 01-23-16, 09:29 AM
  2. bike wont start and charging system not working.
    By Nighthawk83 in forum Bike Maintenance
    Last Post: 07-18-14, 07:01 AM
  3. Charging system troubles and solution
    Last Post: 12-06-13, 03:46 PM
  4. external charging system for my V-strom
    Last Post: 03-03-13, 06:26 PM
  5. ANy body have any experiance with Venom Ramps
    By Vin in forum General Bike Related
    Last Post: 03-01-10, 09:30 PM
