Results 1 to 16 of 16
f4i streetfighter
    What chicken strip??????? NEWTREADS's Avatar
    West Dover VT
    f4i streetfighter
    Im in the middle of streetfightering my f4i. Got the parts, well most of em. just have 2 questions. Any one know where I can get an aluminum plate welded to the top crown for reenforcement (cheap). and what Throttle, clutch, brake lines will work. Need longer ones, but not sure what has same ends on them. Any ideas? Thanks...
    Junior Member nitroduck's Avatar
    Re: f4i streetfighter
    Any welding shop should be able to do it. All they need is a TIG welder.
    Also try exhaust shops.
    If I had my own TIG, I'd do it.
    West Dover VT
    piece has to machine into shape around ignition and up to fork legs as well. I was gettin quotes for several hundred bucks. Tryin to do it cheaper than 100. Thanks tho
    Feb 2010
    Southbridge
    Quote Originally Posted by NEWTREADS View Post
    Wont happen... most shops will charge $150+ just for the welding. theres a reason all your quotes are several hundred bucks..
    Degsy: "i never had red hair"
    As for cables I would look at HAI bike shop and just buy some ones for stunters...they run them all the time on F4i's
    http://www.haibikeshop.com
    I would Drill the Top Triple Clamp and Install a Set of Solid mount dirtbike Clamps. They came in 7/8 (which is the most common Bar size)
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lancaster
    so are you trying to mount dirtbike bars? if so jjust buy risers made for your stock upper tripple
    Corey
    West Dover VT
    150 alone for the weld. Yea I know. I had a friend that had a mill and welders but hes no longer in the area so I figured Id see if anyone has equipment to loan cheap. I have to drill the clamps for the dirt bike bars into the top crown. Only prob there is the aluminum is wafer thin. thats why a plate hast to be cut and welded in. I was looking for an aftermarket one with the clamps built onto it, nada. thanks for the pointer on the cables.
    They do it all the time on F4i's.....go on stuntlife and they will give you all the info needed....many people run DB bars and Heli bars on F4i's..esp stunters for zero deg clipons.....
    I wonder if the Hornet 600 has the same triple?
    West Dover VT
    I already got the bars + clamps (pro atper). My uncle has a small shop in CT I turned the spare/ slightly damaged bins inside out nothing lined up well. Either way I made it this far with hardly 0 investment. Bars clamps and headlight and still under 100 bucks invested. Thanks ebay. The welding and cables are gonna get me unless I can find a set of cables on ebay. thats why I was trying to find a model with the same ends as the f4 has just longer, so I know what to search for. Either way the main purpose for doing this isnt for stunting. Small wheelies and occasional stoppie is enough for me. Mainly stance. I commute on this thing mostly. I use my rc ror the fast fun riding.
    Senior Member Subee13's Avatar
    Feb 2009
    Salem, New Hampshire
    If you commute mainly i have no idea why you would turn it into a street fighter. I would have got helis and called it a day. you are going to get destroyed with wind compared to the full fairings.
    Lancaster
    Quote Originally Posted by Subee13 View Post
    i disagree, i find the wind to be less annoying now then it was before, think about it, the wind is now spread evenly throughout your body, not pointed directly at your face
    Corey
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    +1, I'm a sucker for wind blast!
    Q
    West Dover VT
    The commuting portion is all town riding anyway. Winda blast wont be an issue. Cant really ride the rc51 in town its a pain in the ass going less than 40 on that thing. Doin the change mainly just to check it out, possibly switch it back if need be. Thats mainly why Im trying to do this as cheap as possible. Thanks for all the pointers though. Ill post pictures when I finally finish it.
    Senior Member TimmyB's Avatar
    Southern AZ
    Quote Originally Posted by BLACK SQUIRREL View Post
    i had that idea when i fightered my f3. no dice. i ended up buying a nice set of oversized mounts and bars that worked great, but good luck getting those holes perfect. i used the ebay store pit posse. you can order brake lines to custom lengths for pretty cheap. i think i bought a hornet clutch cable also...it really isnt a hard mod.
  1. Streetfighter V4
    By gixxer72 in forum General Bike Related
    Last Post: 04-22-20, 12:59 PM
  2. Anyone buy a Ducati Streetfighter 848?
    By jwm2k3 in forum General Bike Related
    Last Post: 04-30-12, 11:37 AM
  3. Duc Streetfighter.
    By Rosco61 in forum General Bike Related
    Last Post: 10-28-11, 03:14 PM
  4. Ducati Streetfighter
    By bostongixxer in forum General Bike Related
    Last Post: 07-05-10, 08:41 AM
  5. Friday 22 and Sat 23 Streetfighter
    Last Post: 05-23-09, 05:47 AM
