Results 1 to 5 of 5
Anyone fancy a research project? (Brake pads and retainer pin)
    Senior Member dhawks's Avatar
    Apr 2008
    At some point during my final event of the season, I came back to the paddock without rear brake pads or retainer pin -- just a rear caliper in its normal place. Because the bike is relatively new to me, I hadn't spent any time with the rear caliper, so I don't really know exactly what is missing.
    What I know:
    --It's a 2-piston (piston is 34mm in outside diameter) Brembo rear racing caliper, stamped "8K23" on the caliper housing, and mounts under the rotor with a bracket that allows Japanese bikes to use this caliper. (see photos)
    --I use it on a 2009 Yamaha R6.
    --However, this particular R6 uses a lot of 2009 Yamaha R1 parts, including for example an R1 front end.
    What I think I know:
    --Seems like it's an old Brembo model "P2 34".
    --None of the photos I can find online suggest that there were any clips or springs -- just pads on a pin, which seems odd to me.
    --Seems like these pads would work with this caliper:
    https://motowheels.com/i-23901450-br...rake-pads.htmlhttps://motowheels.com/i-23901450-brembo-rear-caliper-brake-pads.html[/URL]
    https://www.kurveygirl.com/shop/prod...roducts_id=720
    What I can't figure out:
    --What pin do I need to retain the pads in the caliper? Is it even available?
    --Were there springs in the caliper?
    --Keep running into conflicting information and part numbers, etc.
    Anyone have experience with this caliper or any suggestions?
    Thanks.
    Anyone fancy a research project?  (Brake pads and retainer pin)-img_1328-jpgAnyone fancy a research project?  (Brake pads and retainer pin)-img_1329-jpgAnyone fancy a research project?  (Brake pads and retainer pin)-img_1330-jpgAnyone fancy a research project?  (Brake pads and retainer pin)-img_1331-jpg
    /s/ Dustin
    LRRS #767
    '09 R6 / '11 848 Evo / '99 RS250
    High maintenance priss
    Central MA
    Re: Anyone fancy a research project? (Brake pads and retainer pin)
    Hey Dustin - Looks like the part number for the pin (Brembo calls it a spindle) is 120A44170. No mention of a spring. Some of the other rear calipers do have a spring part number, so looks like yours may not have had one.
    Brembo Racing Catalog - See page 33.
    GL
    Apr 2008
    Kian -- A belated 'thanks' -- eight flipping' months later!
    I was able to purchase the pads and spindle. But when I went to spread the pistons to insert the new pads, one piston moved and leaked; the other didn't move at all. Normally this would indicate that a caliper rebuild could be in order, but I simply cannot find any information on the seals/pistons that would form the rebuild kit for this caliper. Intuitively, I know I have 34mm pistons, so part of me thinks I should just buy some amorphous Brembo 34mm piston and seal kit. However, part of me wonders why there isn't any evidence of a rebuild kit for this caliper. Like, anywhere. And the racer, track rider, responsible, survival-instinct-having part of me, of course, whispers "there shall be no guesswork with braking systems, even rear braking systems, you idiot."
    /s/ Dustin
    LRRS #767
    I would just put a stocker back on...
  1. need new brake pads
    By DaveZX6r in forum Bike Maintenance
    Last Post: 03-09-12, 01:19 PM
  2. Brake Pads
    By chris275275 in forum Bike Maintenance
    Last Post: 02-25-12, 12:59 AM
  3. Rounded-off Brake-pad Retainer Bolt Removal Suggestions?
    By dhawks in forum Bike Maintenance
    Last Post: 08-24-10, 10:16 AM
  4. New brake pads
    By Fitz in forum Pit Area
    Last Post: 09-04-09, 07:28 AM
  5. New Brake Rotors = New Brake Pads?
    By highsider in forum Bike Maintenance
    Last Post: 03-27-07, 10:39 AM
