Results 1 to 23 of 23
F'in Ducati Chain - Help?
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Angry F'in Ducati Chain - Help?
    I'm planning to head to PA and points south tomorrow morning, and have been busy so chain adjust had to wait until tonight. Its a'14 Mutlistrada, and I can't get the chain to tighten to save my life. Everything's loose, and I had no problems moving it clockwise to loosen it, but I can't get the damn thing to tighten. I can't say I enjoy what a PITA the chain adjustement is, but I've never had his problem before.
    Any single-sided swingarm Duc gurus out there who can tell me what stupid mistake I'm making? Or it anyone's in the greater Lowell area and is willing to help me get it tightened, there's copious amounts of beer in it for you.
    Dan
    DanG
    - Blaise Pascal
    Lifer SteveM's Avatar
    Aug 2009
    Norwell, MA
    Re: F'in Ducati Chain - Help?
    I have no idea if this will help, but my vfr uses a pin scanner and after loosening it, I have to flip it and reattach it in the opposite direction to get it to pull counterclockwise and tighten the chain.
    Best of luck, problems like this the night before a trip can be really stressfull
    Lifer NPDCPA's Avatar
    Mar 2011
    The pinch bolts at the back of the swingarm are loose?
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    The pinch bolts were loose - at first I made it worse by going clockwise (loosening the chain) - that proved it wasn't tight. After about a half dozen tries and a glass of Scotch, I tried loosening it a bit more then tightening it, and viola! All set. Thanks for the replies gents, now to pack and get some sleep.
    DanG
    - Blaise Pascal
    good travels
    When you get a chance, take that hub out and clean it and the swingarm. If it's starting to bind it's just going to get worse over time.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Wish I read this before leaving for work or I would have let you borrow my spanner. The hub on that gets seized up unless you move it around every once in a while / keep it clean, and can be a serious pain in the ass. I ended up buying a beefy spanner with multiple teeth specifically for my Multi because I went through this last year. The one in the tool kit is useless. Push come to shove and you feel like making a trip I live in Loudon, more than welcome to borrow it. I work in Manch until 5 or so though.
    Just chiming in, same thing happened to me at VIR on my NC30/VFR400. The swing arm was full of small rubber bits from the track, and a bit of sand / grit. Everytime you accelerate any of that shite works its way back to the hub and gets in there.
    I will absolutely be adding removing the hub, cleaning and re-greasing everything to my annual service protocol after losing half a day on track because of a seized hub.
    CCS/LRRS #83
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Thanks, that's a great suggestion. I'll clean it up when i get back.
    Been a great trip so far - Catskills, Skyline Drive, BRP, & Cherohala & the Dragon today. First time I've been down here and they sure have some great roads!
    Sent from my SM-G935V using Tapatalk
    DanG
    - Blaise Pascal
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    Yup. This youtube video does a pretty good job of showing just how much muck / etc. can work it's way between the hub and the Single-sided swingarm.
    I cleaned out mine on my 1199 after watching this vid and there was a whole lot of junk in there.
    Ducati 848 Swingarm Preventative Maintenance & Mod Research - YouTube
    LRRS 919
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    What size socket do I need to get the hub out? Do you know the torque values? One of the things that bugs me about the Multi is that I don't think there's a manual for it - there used to be one on CD, but I guess even that's not available anymore. It makes it difficult to work on the bike with confidence. I guess that's what Ducati wants.
    Where can I find the spanner you bought? The one that came with the bike's toolkit is a piece of shite. I think it's made of aluminum foil. I expect to keep the Duc for a while so having one in my toolbox will come in handy.
    I'll probably replace the chain and sprockets at the same time as cleaning the hub. Usually that's a straight-forward job, but is there anything about the single-sided swingarm that complicates it?
    DanG
    - Blaise Pascal
    Meriden CT
    Motomfg has a nice spanner for $15. I just bought the rear nut socket from them for my Multistrada, great quality.
    Ducati/MV Agusta/Kawasaki/Honda
    LRRS AM# 772
    Boston Tier 1 Racing
    Yoshimura / Lucas Oil / DP Brakes / AXO America / Vortex Racing/ Woodcraft/ Racer Gloves
    Canterbury, NH
    Quote Originally Posted by oVTo View Post
    I haven't actually removed the hub completely myself, but asked for it to be done when I had my 15k service done last November. I plan on doing it again personally after this riding season is over. I didn't see a need for replacing my sprockets when I did my chain last time around, but I don't think there should be anything too weird about doing so.
    As for the spanner I bought... it was this one:
    CORSE DYNAMICS Eccentric Chain Tool: DUCATI Large Axle
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Thanks for the info gentlemen. I expect to take the hub apart this weekend. Anyone know where I can find torque values?
    DanG
    - Blaise Pascal
    Nov 2009
    Bristol County
    You want to find a service manual. Which the ducati forums probably have a link to in the sub-section specific to your bike. Super handy. If not, I'm sure one can be purchased from a ducati specific vendor.
    Otherwise, tight till it gets easier, then back a half turn. Then make plans to never touch it again.
    nedirtriders.com
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    I tried to find a service manual when I bought the bike. I think Ducati offered one on CD for a while, but I went Seacoast to order one and they said that it's not available. I checked ducati.ms and found threads saying the same thing. There was a link to a bootleg version online for a 2010. That should be close enough. eBay has some bootleg 2013 service manuals, but I don't know whether they're just the 2010 version or really the 2013 model. The 2010 should be good enough.
    It does piss me off that Ducati doesn't offer a service manual for their bikes. I'm surprised they don't tell you to take it to the dealer when the gas tank needs to be refilled. But then again, with the defective gas gauge on the Mutli, the only way to know if you need gas is the old fashioned trip meter.
    DanG
    - Blaise Pascal
    I have a 748 and not sure its the same setup as your multi. I take you got the toque values from seacoast? I found the C-clip that holds the hub in to be a bigger issue if you don't have the right size pliers for the job.
    If you need a spanner I have one and I'm in Woburn.
    Here's a service manual for monster 1200s and the adjustment direction should be the same.
    https://1drv.ms/b/s!AsEneqqYopvxkwtZ_zPPGp9roAM_
    Look on page 89
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    That's what the guy in the video was saying, that the C-clip was a pain and took a long time. I have a decent C-clip tool, but since it's a common complaint I'll just be patient getting the clip off and back on. I got the torque values from the online manual for the 2010.
    DanG
    - Blaise Pascal
    Canterbury, NH
    You having intermittent fuel level sensor issues with yours as well?
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Yes. It's a known defect, and apparently was covered under warranty if you caught it quickly enough. Mine didn't fail soon enough. It's a cheap plastic part, and the replacement is metal. I think that's considered a real fix, not just a patch. But it's expensive to replace, I think about $100 for the part and $100 for labor because it requires taking the tank off which I guess is a PITA. I'm not sure whether I'll drop off the bike, just the tank, or try replacing it myself. Depends on how lazy I get this weekend and how nice the weather is.
    DanG
    - Blaise Pascal
    Canterbury, NH
    Yea I'm debating on what to do with mine as well. After 2.5 seasons it finally started failing this spring, then started working normally again. On the way back from NY this past weekend it tripped up again. I do need fork seals replaced, I'll probably just have Eric @ Clubhouse take care of both once the season winds down.
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Mine worked for about a half year (I bought it used), then failed once in a while, but after a year or so it worked its way up to almost all of the time. Now it only occasionally 'works' but usually display a known bad value (i.e. all the bars when I'm 75 or 100 miles into a tank). It looks like I was wrong about the replacement being a fix. I checked the forum and it looks like they're on Rev E of the replacement and still getting failures. Now I'm not sure I'll replace it with some kind on warranty on it (probably not possible).
    It can be replaced with a resistor (about 22 kOhm) to keep the engine light and warning off and the gauge bars from flashing. A few people have disassembled the unit and re-soldered everything. Not sure that provided a long-term fix or not. Maybe Rev F will work.
    DanG
    - Blaise Pascal
