Results 1 to 11 of 11
finally bought bike/carb question
    Member dj 96yzf750's Avatar
    springfield mass
    i just bought a 94 Suzuki rf600r,it has only 7k miles on it,exterior looks great but the bike idles fine and everything but when around 8000 rpm and higher the bike hesitates a lot, i put some sea foam in and mixed it around and ran the bike on choke for a while,should it do the trick?
    Wirelessly posted (BlackBerry8530/5.0.0.337 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    Blocked main jets?
    springfield mass
    Re: finally bought bike/carb question
    yeah that is what i was just guessing,just hope the sea foam works a miracle
    Raymond NH
    Do main jets really clog? I'd think the pilots would be clogged long befroe the mains. Can't say I've ever had to clean a main jet on any engine.
    I'd be looking at ignition components.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Check your fuel filters and that gas flows good out of the petcocks as a cheap (0$) easy first step.
    springfield mass
    ok carbs where spotless,and my bike dosent have a fuel filter
    Waterbury, VT
    Quote Originally Posted by dj 96yzf750 View Post
    More than likely the filter is in the tank attached to the petcock assembly.
    If you haven't done it already new plugs are never a bad bet on a bike you just bought.
    SSearchVT
    And also check the gas cap for a plugged air vent. In another words verify that you are getting enough fuel into the carbs to support higher RPM's.
    Yeah, it sounds to me like it may be a fuel flow issue....
    Easiest way to check is to pull the fuel line where it attaches to the carbs, stick the line in a fuel can & check the flow.
    Check the petcock. Is it vacuum actuated? Does it have a "prime" position? If so, try running in that.
    If that doesn't work, perhaps it's a float level issue?
    springfield mass
    ok so i pulled the fuel pump its working fine pulled carbs,there clean ,i am going to run through the fuel lines and petcock and vacuum lines today,
    Savannah, GA
    im with pete, check float levels.
    How is your spark?
    Are all the hoses/vents hooked up correctly? That causes issues sometimes. May have issues if float bowls need to be pressurized and a hose is dicsonnected or something.
  1. Carb Question...Can't get it right
    By MikeyZ in forum Bike Maintenance
    Last Post: 04-16-11, 12:06 PM
