Results 1 to 2 of 2
Finishing rattle can paint
    The side covers on the BMW R90/6 are held on by a bungee cord between them. The left is captured by the grab handle, but the right can fly away: DAMHIKT.
    Had a body shop supply store match the paint , which turns out to be a GM Color called “Pull Me Over Red.” They supplied me with an aerosol made by SEM, their paint supplier.
    Problem is, there are no instructions. The panel came primed, so I’ve put on several light coats, wet sanding 400 grit in between.
    Now ready to put on the final coats, but not sure what grit to sand with before, and after. I have up to 1,000 grit (and can get higher) and some rubbing compound. It’s a side cover so anything will b3 “good enough” but next project is a small fairing, much more visible.
    TIA.
    Re: Finishing rattle can paint
    The more time and coats the better results. I did a hawk tank once took me a few weeks but the results were awesome. Dont remember what grit I ended with and after a few wet sandings I dont think it matters that much. More a deal of how light or heavy the paint goes on. And how many coats you do? But after five or six it's a time thing. How much time do you have? Or want to put into it? You will get to a point where it wont change the results ..... Dont over do the clear coat... good luck.!
  1. Rattle can paint job
    By 01xj in forum General Bike Related
    Last Post: 04-20-18, 12:19 PM
  2. Masking tape on rattle can paint job?
    By StrayNut in forum Bike Maintenance
    Last Post: 04-22-14, 11:41 AM
  3. question for rattle can paint pro's.
    By boosten lebaron in forum General Bike Related
    Last Post: 07-08-13, 06:50 AM
  4. Paint: Rattle-can match?
    By AimlessMoto in forum Bike Maintenance
    Last Post: 06-27-11, 06:41 AM
  5. Rattle can paint suggestions
    By intergalactic in forum General Bike Related
    Last Post: 03-26-10, 05:28 AM
