Results 1 to 25 of 26
fixing a bent rearset
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    I've got a woodcraft rearset that was bent during one of my several offs this year. I've been told that I can apply heat and bend it back in shape but I've never tried. So, do I just take a torch to it and hammer it back in shape or is there some trick to it?
    Windham NH
    Re: fixing a bent rearset
    I was able to bend one of my woodcraft brackets back by putting the frame mounting bolts side of it into a big vice, then a big adjustable wrench on the other end and pulling hard. No heat needed. I did almost rip my dad's workbench out of the wall doing this. Had to find a heavy bench/vice
    Lifer Trouble's Avatar
    Monkton, VT
    Heat and a deadblow/vice work but you need to be very careful. The more heat you apply and the more times you heat it the softer the aluminum becomes. It never fully regains its strength. I'd recommend straightening it and keeping it as a spare.
    LRRS EX #7
    Low Down Racing
    HAMMER!
    and if that doesn't work.
    BIGGER HAMMER!
    Jul 2014
    Central CT
    ^^ fixing a bent rearset
    That's the plan John. I just want to have an "ok" spare rather than one that's all crippled.
    No heat!
    I'm fairly certain I was told that by Woodcraft directly, but I can't find the reference.
    Lancaster, CA
    Hammer. Lots of hammer. Bending it SLOWLY with a pipe/pry bar as a second option; but that's not been successful for me in the past.
    Bill Cool --- CRA EX #47 --- 2023 NEMRR GTO Champion, 2020-21 LRRS LWSS Champion --- RSP Racing / TTD / MTAG-Pirelli / Woodcraft / Sportbike Track Gear / Seacoast Sport Cycle
    Jul 2014
    Central CT
    Thanks for the tip guys. I'll try my hand at it tomorrow. First without heat. The bracket might not be too much of an issue but that brake lever could be a bit more troublesome. Here's a picture of what I'll be starting with.
    fixing a bent rearset-img_1367-jpg
    Attached Thumbnails Attached Thumbnails fixing a bent rearset-img_1367-jpg
    I thought they came that way on an SV???
    Jul 2014
    Central CT
    What irritates me the most is I think I had maybe 1 day on that rearset.
    Good luck. I was not able to straighten the bracket on mine. No matter how much I hammered it.
    BIGGER HAMMER!
    This one?
    For the lever Id put a deep well socket over the tip and then put on the longest extension you have while holding the bracket in a vice. Bracket doesn't look that bad. Shouldn't be hard!
    that might distort the threads for the toe shifter when you bend it back. if it's just that arm, i'd plan on replacing it.
    Jul 2014
    Central CT
    This entire unit is my spare. But I suppose I can always have a spare for the spare.
    May 2010
    Somersworth, NH
    ive had success just laying the bracket and levers on a concrete surface, bowed side up, and just hammering it steadily until they flattened back out or close to flat atleast.
    I've raced with worse. At the risk of contradicting the bigger BFH stalwarts, that bracket would probably work as is, and the lever could be sawed (sawn?) off and another hole drilled for the lever end. The screw(s) may need some heat to release the Loctite. More pertinent to the discussion, is the pivot (dark piece) stuck on the peg? Every drop I've had, that peg needed to be pressed out and filed down because the end mushroomed and seized the pivot. Is this the one we had to Helicoil the mounting tabs for on your bike?
    Alternately take it to the track and have some young lady ask for help with it, and a swarm of helpful lads will come to the rescue.
    I seriously doubt that since the screw is in there while its being bent back. And the surface that contains the hole isn't bent...it's bent slightly further up the shaft. It'll be fine.
    Jul 2014
    Central CT
    Well. This is what happened when I took a pipe to the lever.
    fixing a bent rearset-image-jpg
    Better appreciate the picture. Took me 10 tries to get the phone focus correctly.
    I will be cutting the end off and drilling a new hole. Before the pipe there was endless hammering. I needed a bigger hammer but did not have one. Should have listened to John and applied some heat.
    I blame the hammer.
    My bike doesn't even have rearsets.
    rides bikes
    Nov 2014
    Woodcraft advertises that you can bend their rearsets and parts back 90 degrees (maybe even 180) without breaking them. Might be worth a phone call for some free stuff.
    I may not be qualified to respond, but I believe I speak for many when I say "WTF are you talking about??"
    I knew that wasn't gonna work. Aluminum straightening is a one shot deal. If it's jut bent a little you have a better shot. But at 80 degrees or so it ain't likely.
    I believe the engineering term is "knee". Aluminum doesn't really have one.
    the part costs like...$20.
    who cares?
  1. Ice trick for fixing your 2t pipe
    By slowkermit in forum Dirty Bastards
    Last Post: 03-01-13, 02:42 PM
  2. We need help fixing bent rims on our SV!
    By souljah996 in forum Pit Area
    Last Post: 07-15-07, 03:58 PM
  3. Fixing a totaled bike?
    By Cooter in forum General Bike Related
    Last Post: 05-29-02, 03:22 PM
