Results 1 to 25 of 26
Valve Clearance the fast way
    step one - smash your bike into a jersey barrier at 100 MPH
    step two - shatter your valve cover.
    step three - check valves
    for additional space, try to break the neck of your frame off the bike.
    that's it. no need to remove the tank, air box, spark plugs, coils, etc. see all that time saved?
    Valve Clearance the fast way-img_2961-jpg
    Attached Thumbnails Attached Thumbnails Valve Clearance the fast way-img_2961-jpg
    Re: Valve Clearance the fast way
    I'd be afraid to get dirt in the motor that way...and broken valve cover parts
    Mmm...motul 300v.
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Does anyone check it another way? They're living in the Stone Age!
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Next thread how to remove the triple the fast way
    Dec 2003
    Ma
    Step .5 gas and brakes at the same time coming into turn 3?
    Mmm...motul 300v.
    isnt it annoying hearing people tell you that you're using antifreeze?
    it's been discovered that the throttle was stuck open while applying brakes. while you're correct, this result was from a mechanical failure and not rider error.
    Lifer ilikenapalm's Avatar
    Connecticut
    Were they within spec?
    Obligatory - That'll buff out.
    Wirelessly posted
    Obligatory- he uses all the power
    Infected Slyder's Avatar
    Concord, NH
    Mmm...motul 300v.
    Smells like nanners
    Wirelessly posted
    Obligatory- get a bunch of guys to lift it.
    Dec 2003
    Ma
    Didn't say why it happened, I just heard how it happened when I watched the video, and was unable to let you know there.
    I get credit on 2 out of 3 of Obligatories huh? DB and Smutty are on the way to making me famous for another one.
    Lifer Falko's Avatar
    MoonTown
    So adjusting a chain for you involves a ramp, flaming hoop, and barbed wire fence??
    Banned G21forme's Avatar
    Lakes
    It actually does involve a fence.
    Jun 2005
    What does this bike have with fences and walls and whatnot?
    at least i gently placed it on TOP of the jersey barrier
    Quote Originally Posted by Jimmy Faceplant View Post
    Ahhh so that's why I heard you were using antifreeze. That blows that the rumor went around.
    300v != antifreeze
    my radiator is actually just bent, but not leaking.
    I heard it over the Radio on hot pit and Told Heath its Motul.................I would say Oil and Antifreezer are real easy to tell the Diff
    the corner workers never asked me what i have for oil. i know it's typically the 2nd thing they ask after making sure you're ok.
    yup same here they said 105 was leaking antifreeze
    Hiram, ME
    Smutty; you've been teaching people to check valves the wrong way.
    Massachusetts' Noth Shoah
    That'll buff out.
    Edit:
    Did not see post nine
    More attention I must pay
    Maybe ride flaht out.
    Go fast. Have fun. Repeat.
    May 2007
    Southern NH
    Fak Jim....you never cease to amaze....
    Muhammad Ali.
  1. check valve clearance on 01 gsxr 600?
    By burtonboarder23 in forum Bike Maintenance
    Last Post: 02-26-13, 10:33 PM
  2. Doc's Bike Clearance
    By Doc in forum For Sale
    Last Post: 11-19-11, 04:52 PM
  3. What makes the fast woods guys so fast?
    By gregp in forum Dirty Bastards
    Last Post: 10-18-11, 02:02 PM
  4. Valve Clearance Adjustment
    By slammp in forum Bike Maintenance
    Last Post: 12-31-09, 05:32 PM
  5. Valve clearance check- where?
    By nerijusj in forum Bike Maintenance
    Last Post: 03-13-08, 08:26 AM
