Page 4 of 4 FirstFirst 1234
Results 76 to 87 of 87
What if you get a flat?
  1. #76
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Re: What if you get a flat?
    Thanks guys!!!
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    So I assume the rubber mushroom plugs are better option than the rope plugs? Is there really any difference to doing a rode side plug as opposed to a mechanic fixing it? Or are they just going to use the same tools? And what is better for longevity?
  3. #78
    Lifer NobodySpecific's Avatar
    Apr 2008
    Burlington, VT
    I've used a rope plug in tires on my bike and my car, and neither one failed on me. I put a few thousand miles on the rear tire of the bike after using the plug and didn't have any problems. In both cases the tire wore out before the plug failed.
    '06 Triumph Sprint ST ABS
    '90 Yamaha XT350
  4. #79
    Derry NH
    I prefer the rope style plugs. The way they work is they are actually un-vulcanized rubber. Riding/driving heats up the rubber so it vulcanizes and becomes part of the tire. Either one can slowly leak if done improperly/poorly, but this is the method I prefer. And the only one I've ever seen used by a mechanic, save for dismounting and patching from the inside.
    NoChelmsford, Ma.
    Wow really? OK that's interesting. And good to know.
  6. #81
    Raymond NH
    I agree on the rope plugs being superior to the stop-n-go mushroom plugs. They do last longer and you can add another plug to the same hole if needed. I have a trailer tire with 4 plugs in the same hole, plus a 5th that passes through the loops on the inside. The mushroom plugs, with the wire center, that need to be glued from the inside are probably the best.
    Senior Member AEG's Avatar
    Aug 2012
    Simsbury, CT
    Quote Originally Posted by 35racer View Post
    Maybe I missed it, but why wouldn't you want to join the American Motorcyclist Association and get towing for ANY vehicle you own... for you and your entire family?
    That's fine for a flat tire... but the coverage is for anything that happens... in anything you own (car, truck, trailer, bike, rv)
    From the AMA link:
    "Towing services are covered up to 35 miles to the nearest qualified service facility (or to any other location requested by the member of equal distance at no expense to the member). If over 35 miles, the member is only responsible for the overages incurred after the 35-miles coverage"
    What is the cost per mile after the 35 miles coverage is exceeded?
    maybe my next rear tire will be a runflat
  9. #84
    Lifer golden chicken's Avatar
    Attleboro, MA
    Do they make run-flat snow tires?
  10. #85
    yes, the General Altimax Arctic I have is available in runflat
  11. #86
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Most people using a runflat also recommend getting a TPMS.
    Runflats are good, but aren't intended to be used indefinitely.
    Lifer SwiftTone's Avatar
    Norwood, MA
    I'm really considering one. I have a car repair kit which looks okay but want to replace it with something better. Also looking into air options. I am leaning toward a manual pump.
  1. Flat track
    By MaRce1o in forum Pit Area
    Last Post: 03-15-16, 05:27 PM
  2. Flat tire, need some help.
    By palanon in forum Pit Area
    Last Post: 05-22-09, 08:20 PM
  3. Flat spot in rim
    By superbrew in forum Bike Maintenance
    Last Post: 05-21-08, 06:18 PM
