Results 1 to 25 of 34
Float Bowl Screws
    Lifer Pittenger5's Avatar
    Austin
    Float Bowl Screws
    Im gonna need to easy out a couple screwed on my CRF250 float bowl. Is there a way to find out what screw that is and see if I can get it locally rather than the "official" Honda part that I need to pay 8 dollars for at the dealership, or 14 dollars to ship 3 screws from an online company?
    Part NUmber: 93892-04014-08
    Zip Tie Alley #505
    Rochester, NH
    Roland Arsenault
    LRRS and USCRA #763
    Austin
    Re: Float Bowl Screws
    That's my question, what will work
    Zip Tie Alley #505
    Rochester, NH
    Googling the part number, this is the first hit: 93892-414-8 SCREW-WASHER (4X14)
    Based on that, I'm guessing a 4X14 screw would do the job.
    Of course, we just need to wait a bit and Kurlon will set us straight.
    Roland Arsenault
    LRRS and USCRA #763
    If you're going to the bother of purchasing, Allen head stainless is much nicer.
    Austin
    Kurlon to the white courtesy phone please! The red zone is for loading and unloading only!
    Zip Tie Alley #505
    Roland is correct, based on the PN those should be M4 screws, 14mm long. The link Roland provided will work, or you can grab allen head hardware as well. If going allen head, remember that it's very easy to overtorque that size screw.
    Austin
    What pitch do I need? The ones on amazon say 0.7mm
    Zip Tie Alley #505
    This is metric hardware so it's as easy as M4x14
    Feb 2009
    Lost in constant migration
    Should be fairly easy to find, but if your local hardware store doesn't have one and you have a hobby shop around they'll have bags of them cheap, it's a common RC screw.
    Those screws are JIS screws. Using a Phillips on them is stripped - head suicide.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Roland is spot on. Also +1 for getting allen head. Also spring for a a set of JIS screw sticks. They are not cheap but worth every friggin penny.
    Austin
    Well, bought allen head pack of like 30. That should last me a while.
    Zip Tie Alley #505
    Rochester, NH
    The original part also mentioned a washer, just in case you missed that part.
    Roland Arsenault
    LRRS and USCRA #763
    Austin
    Quote Originally Posted by rolker View Post
    I can just reuse those off the old screws though, right?
    Zip Tie Alley #505
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Yes.
    Sure.
    Rochester, NH
    The experts say yes, but I just wanted to mention it in case the originals got damaged somehow.
    Roland Arsenault
    LRRS and USCRA #763
    Austin
    We need to rename the "tech" section to the Kurlon section.
    Zip Tie Alley #505
    Rochester, NH
    I've never seen Kurlon as happy as the day I rebuilt my motor at the track and I let him fondle the internals.
    Roland Arsenault
    LRRS and USCRA #763
    New Haven-ish, CT
    Unless you snapped the head off, just cut a slot in the head with a dremel to use a flathead screwdriver.
    Then take them down to your local Ace or True Value hardware store (not Home Depot or lowes) and get the right length Allen head stainless screws.
    And use the JIS screwdriver that came in your bikes toolkit next time.
    Austin
    The 12 year old bike that's been through about 9 owners since new? Yeah, Ill get right on that toolkit.
    Zip Tie Alley #505
    Holy shit yes. That was fun to spectate like 3rd hand.
    Maybe I'll bring the KTM up and we'll do a top end after awards some weekend this spring?!
    a hand impact driver is your friend
  1. Replies: 6
    Last Post: 06-20-11, 05:27 PM
  2. setting the float XR200R
    Last Post: 09-25-09, 10:21 PM
  3. carb float repair
    By BMFR6 in forum Bike Maintenance
    Last Post: 03-29-09, 10:49 AM
  4. FS: Ice Screws
    By jtaylor719 in forum For Sale
    Last Post: 11-13-08, 01:34 PM
