Results 1 to 10 of 10
Fork oil weeping...
    professional lurker burtonboarder23's Avatar
    Nashua, NH
    Fork oil weeping...
    So while out for a ride at lunch i happen to look down and noticed a very small amount of fork oil on on the top of the fork. I thought it was just road grime so i wiped it away and after a little riding i noticed more. Any ideas or should i just call pete for a fork rebuild?
    Fork oil weeping...-img_1630-jpg
    "Could you elaborate on that a bit? Just telling me not to run a specific tire, and giving me no true logical explanation is like telling me I'm going to get my dick sucked tonight, and not by whom."
    Nashua, NH
    Re: Fork oil weeping...
    anyone?
    Did a little riding this weekend to try out my new shorty levers and saw no fork oil anywhere.
    KNEE DRAGGING BAGGER sedanman's Avatar
    Oct 2014
    Pawling NY
    I was told that if oil can get out then air can get in and the forks can "pump up ". I'd at least get new seals.
    Raymond NH
    That's not where fork seals leak. Looks like bad o-ring in the cap to me. Should be a simple fix. What year/model bike?
    Nashua, NH
    08 cbr 600.
    Raymond NH
    I don't think Honda sells parts for that cap, you need to buy the entire cap from them for 33 bucks. I'd try to take it apart and see if it can be fixed with a new o-ring, or set up a camera to catch the guy that's putting drops of oil on your fork caps while you're not looking.
    Feb 2004
    Bellingham, MA
    Yes, looks like it. i can get orings, but to get to them will require a regular service.
    Nashua, NH
    Sent you a PM
    It's more likely to be brake fluid from an over filled brake fluid reservoir than a leaky fork top. When the brake fluid heats up too mu ch (or if there is water in it) it can expand and spray out of the cap onto the fork tops and top triple/windscreen etc.
    Senior Member myzx6's Avatar
    Apr 2014
    Riviera beach fl
    If it is brake fluid you wanna make damn sure that you don't let it sit on anything painted because it won't be painted for long
  1. Fork Oil
    Last Post: 08-31-12, 05:15 PM
  2. Replies: 7
    Last Post: 07-08-11, 11:07 AM
  3. Fork You
    By Cowboyrider in forum Bike Maintenance
    Last Post: 09-02-10, 04:10 PM
  4. Changing a fork seal/fork oil??
    Last Post: 08-11-10, 07:58 AM
  5. fork oil
    By Punjistick in forum General Bike Related
    Last Post: 09-07-06, 08:22 PM
