ok, some racetech .95kg springs are in the mail for my gsxr front end on the sv. i found them cheap on ebay, so im not sure if they come with all the neccessary hardware...but hopefully they do.
does anyone have experience with swapping these springs? they are 05 gsxr 750 forks. im guessing i would
-remove top fork cap
-compress the spring via spacer with brute strength or spring compressor
-remove top cap by loosening jambnuts
-remove spacer
-remove spring
-put new spring in
-put same old spacer in
-drain oil, set new oil height (7.5wt) with springs in, and upper tube all the way slid down. (or all the way up?)
-bleed by pumping forks
-install top cap
basically, will i need different length spring spacers? and do i need to remove the bottom bolt holding the cartridge assembly to change fluid?
thanks for any help.
