Results 1 to 11 of 11
1975 RD350
    Member clutch's Avatar
    Oct 2008
    1975 RD350
    The bike: 1975 RD350
    I am having a problem with this bike and I can’t get a handle on the issue.
    1) It will start up flawlessly.
    2) It will idle fine.
    However, when you hop on and ride it, it appears to run on the right cylinder and the left only comes alive at around 7K RPM’s
    Fuel system: Fresh gas, good flow.
    Ignition system: New plugs, points look good I have tried to adjust them. However I don’t have a dial gauge for a true setting.
    I am hoping that someone here on NESR has some good experience with RD 350 or knows of a shop that does.
    Thanks.
    Current whiplist:
    MST/Pikes Pike---------Transformer/Sky Hooked
    1098s-------------Interstater/Time machine( Just sold)
    DRZ 400 Tarded---Urban assault vehicle
    Road King---------Date bike/ Hangover bike
    XT 225-----------Grocery getter/Packie bike(For Sale)
    RD 350---------Giant Killer
    Past whiplist, I drink to them all.....
    metal for the masses jpallein223's Avatar
    May 2010
    Lebanon CT
    Re: 1975 RD350
    have you tried syncing the carbs? just had to do so to the rz. now it runs amazing. that or make sure the carbs are all cleaned and you have the right jets
    Lifer catamount's Avatar
    Sep 2006
    Colchester, VT
    Re: 1975 RD350
    Have you checked the points? Doesn't explain why one cylinder would be stronger than the other, but we had an engine that would bog down under load and the problem was worn points.
    Massachusetts' Noth Shoah
    Re: 1975 RD350
    Bad ground involving that coil / plug lead?
    Go fast. Have fun. Repeat.
    Member VTRumble's Avatar
    Kingston, MA
    Re: 1975 RD350
    www.2strokeworld.com lots of good stuff there.
    Re: 1975 RD350
    Clogged main jet.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: 1975 RD350
    I would tend to agree with Bergs.... Is there a spark when you just kick it over? Does it go away when it's HOT or just under load?
    Posted by Jane in BoxChat
    Oct 2008
    Re: 1975 RD350
    Thanks for the great tips and link.
    What I have done so far is:
    I have taken apart the left carb, because of the suspect of bad firing within that cyclinder.
    Replaced the left coil.
    I guess my next approach will be the points. And carb, sync.
    Very frustrating!
    Thanks again.
    Current whiplist:
    Jul 2006
    Albany, NY
    Re: 1975 RD350
    glad to see another rd owner. I just did all that to the carbs and points (new) and it runs just ok. I took it on a 30 mike ride and it started to die then couldn't keep running. think I have a charging problem.
    good luck
    Member Ri_De_bike's Avatar
    Jun 2005
    Road Island <lol>
    Re: 1975 RD350
    clutch
    75 Rd 250 here, most of running problems with the RD series is usually timing. get a dial gauge and a check lamp. gap the points then set the timing to 1.8 btdc BEFORE you do any other work; carbs, coils etc.
    you'll be like a dog chasing its tail if the timing is off.
    "Does this scooter make my butt look ...fast?"
    Lifer Stromper's Avatar
    Eastern Ct
    Re: 1975 RD350
    Back in the day I had 2 of these
    Stock coils etc very weak
    plugs become partially fouled almost immediately
    Many just upgraded almost immediately to aftermarket electrics
    pvl ignitions is one
    Look at a antique motorcycle publication called walnecks
    There is a CALI company that sells RD parts and has an electronic ignition upgrade that ends the problem.
    I ended up on my cafe having CAR COILS screw clamped to the front frame.
    Some guys who ran high compression power would start the bike on HOT plugs then when fully hot swap out to cold range plugs so she wouldn't detonate
    Other than that have fun
    There is a microscopic possibility that the reed valve on that side not seating but 98% would be weak coils
  1. 74 RD350 seems fair
    By Stromper in forum General Bike Related
    Last Post: 02-17-17, 03:36 PM
  2. WTB: Yamaha RD350
    By xxaarraa in forum Wanted
    Last Post: 01-10-13, 09:11 AM
  3. 1975 RD350 jetting
    By suthington13 in forum General Bike Related
    Last Post: 09-16-12, 12:43 AM
  4. Any rd350 peeps on here?
    By boosten lebaron in forum Bike Maintenance
    Last Post: 08-24-12, 09:11 AM
  5. Yamaha RD350/400
    By Rosco61 in forum General Bike Related
    Last Post: 01-28-11, 01:39 AM
