Heres the scoop. My front brake lever sometimes feels abnormaly soft. today I squeezed the lever to see if it felt "spongy" and I was able to pull the lever all the way to the grip??? I then pumped the lever maybe 2 more times and it was back to normal again, leaving around a 1 1/2 inch gap between the grip and the lever...Like a car break pedal feels when you put new pads on and you pump the pedal the first time, it goes to the floor and then it goes back to normal..??? Does this mean I have air stuck in the lines??? ANy help would be greatly appreciated thanks.
