Results 1 to 21 of 21
Front brake lever play, air in the line?
    Jul 2006
    Hollis, NH
    Unhappy Front brake lever play, air in the line?
    I replaced my front brake pads last week. This week I'm noticing that the first pull on the lever seems to have more travel than I'm used to. If I pump it a couple times it tightens right up like I remember. There's plenty of braking, it just doesn't seem to kick in where I'm used and that reaction distance seems to vary depending on how long ago I hit the brakes. There's plenty of fluid in the reservoir and everything is tight. Could I have gotten air in the lines somehow or is this a sign of another problem?
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Front brake lever play, air in the line?
    Sounds like you need to bleed them to me.
    Lifer R1's Avatar
    Somewhere you dont know...
    try the zip tie bleeding trick, then bleed the master cylinder and calipers again.
    open the reservoir put a couple zipties on the broke lever and let it sit for a couple hours. just be sure to put something over the fluid so nothing falls in.
    then just be sure to bleed them one more time after they sit.
    definitely sounds like air in the line.
    I bought a small hand vacuum pump for bleeding my brakes. workes great for one person brake bleeding. it was like $20 at autozone or something like that. It has a small bottle to catch the fluid and a tone of other attachments to do other crap with it.
    Sticking seals and/or crud on the pistons can cause the pistons to overtravel back into their pots, thereby increasing the volume of fluid necessary to push the pistons towards the pads. If you didn't clean the caliper assemblies while you had the pads out, you may want to take a look there.
    Jul 2006
    Hollis, NH
    I bled the lines and saw no bubbles which I sort of expected since I didn't open them up when I replaced the pads. Upon further investigation of the symptoms and troubleshooting I have unfortunately learned I have a warped rotor. It all makes sense now ....
    The warped rotor compresses the brake pistons while riding. When I apply the brake, the pistons now have further to travel since they've been recessed by the warped rotor tapping them. Once I've extended them by pulling the brake lever they act normally.
    All you expert wrenchers probably already knew this but I thought I'd share my story for those that didn't and suffer the same symptoms.
    Member TimD's Avatar
    Woburn
    Shouldn't the warped rotor also cause tons of vibration under any braking? Its always been my experience that a warped rotor makes it vibrate well before noticeably affecting travel.
    Tim
    '05 GSXR1000
    Jul 2006
    Hollis, NH
    No, not a ton. Very slight but now getting worse. Rotors are on order.
    rob did you order stock or an aftermarket upgrade?
    Lifer Wishbone's Avatar
    Jul 2006
    Check your tire pressure and oil leval
    Jul 2006
    Hollis, NH
    EBC Pro-Lite Contour
    excellent choice cheese. i'm looking into gafler wave rotors after i do SS brake lines
    Jul 2006
    Hollis, NH
    I looked at those too. Very nice!
    Leo loridin64's Avatar
    Outside Lowell
    i have a set EBC's. They're great.
    2002 RC51
    USMC - Semper Fi
    POW/MIA - Not Forgotten
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    You just need to get a different bike!!!! Your bike has bad karma!
    KB KB's Avatar
    Manchester NH
    Whoever changed your tires probably bent the rotor.
    Fuckin hack.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Quote Originally Posted by Billy View Post
    Southern, NH
    Yeah....damn GixxAH's!!
    Jul 2006
    Hollis, NH
    Quote Originally Posted by rmbbikes View Post
    Fuckin hack.
    I think I over heated them at the track.
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by Cheese-GSXR View Post
    Dude there is no way you warped them at the track. In order for that to happen you would need to go "FAST" at the track no?
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jul 2006
    Hollis, NH
    Throttle=Go Fast
    Brake lever=Go Slow
  1. Wanted - Parts & Tools | '05 KTM 560 SMR Front brake lever OR Master Cylinder for Motard
    By Ductard in forum Wanted
    Last Post: 07-02-14, 11:36 AM
  2. Front brake lever microswitch + brake bleeding
    Last Post: 05-05-11, 07:52 AM
  3. WTB: GSXR clutch lever & front brake fluid resevoir.
    By OreoGaborio in forum For Sale
    Last Post: 05-24-09, 05:07 PM
  4. Wanted: Front brake lever
    By catch2otwo in forum For Sale
    Last Post: 01-16-08, 03:33 PM
  5. KLR 650 Front Caliper and Brake line
    By mycirus in forum For Sale
    Last Post: 04-14-07, 06:45 PM
