I got a set of Carbone Lorraine C59 Front Brake Pads for the SV.
I remember hearing that you should scuff up the rotors with sandpaper and then use brake cleaner. Is this correct?
If so, what grit sandpaper? My shop manual doesn't mention this step.
Also, for a track bike do you use the brake grease on the back of the pads?
Thanks
