Page 3 of 3 FirstFirst 123
Results 51 to 65 of 65
Front End Swap VS cartridges
  1. #51
    Re: Front End Swap VS cartridges
    But only with a JUST SWAP THE ENTIRE BIKE FOR A RADIAL MASTER because RADIAL MASTER
    Fixed.
    2016 BMW S1000XR
    Feb 2004
    Bellingham, MA
    Fixed.
    Or you can just get a few guys to lift it up.......
  3. #53
    Pete thank you so much!
    Fixed.
    I'm confused. Which cylinder is the master cylinder? #1?
    and having a compression damper in one side and a rebound damper in the other side may contribute to Fork Twist..... I'll be brief about this one, pure unadulterated bullshit. Well unless you are using a wooden stick for an axle, then yes, it will.
    I think you proved this wrong on the converted forks that you did before I did the full swap. It worked awesome.
  6. #56
  7. #57
    Milford, CT
    Because this is the internet, I'm going to write about whatever I want to to keep this thread going, rather than contributing to the OP's purpose.
    Be aware, you can go OVERLY stiff on the front suspension and overwhelm the frame. No idea if that's an issue or not on the EX but it's something to be aware of.
    On the SV, it's *almost* nonexistent. I've ridden a G2 SV650 with 1.2's (IIRC) and it felt marvelous.
    Off topic but tangentially related:
    I rode Kurtz' EX and Rada's SV back to back and pushing pretty fricken hard at NCBIKE. It was enlightening. Rada's set up was at the extreme end of stiff (spring wise), and Kurtz' was much more in my wheelhouse. Rada has a steering damper, Kurtz does not.
    The EX was immediately easier to turn, and loves to be cranked all the way over. Handles amazingly when on the edge of the tire. It's much narrower and lower COG than the SV. It was quite a bit less stable than Rada's SV though, and at this high speed track, I think that was a penalty. I went off track in the high speed final turn and had a WILD ride through the grass. I didn't quite get a precise line going in and I spun and drifted a little wide, and that was that.
    Rada's bike was a puzzle to me. In the first lap I thought, "I can't ride this thing, it won't turn". But I stayed out there, and began trail braking into the turns to get the bike laid over. Once I did that, it was stable as a rock mid corner, and I could open the gas WOT without losing my line. The wider tank and frame actually made it easier to relax at max lean angle. I was not working hard at all to go fast on it. The bumps would set me sideways a bit though.
    On that track, on that day, a SUPER stiff SV was my pick. At Loudon I have preferred the EX.
    Though I didn't ride Kurtz's EX at NCBIKE, I have ridden it before (can't remember whether at NHMS or NJMP-L). Regardess, I felt the same as you when first jumping onto Rada's SV at NCBIKE...goddamn if I don't love a big stiff SV
  8. #58
    Quote Originally Posted by Mustang View Post
    then you need to try a 1st gen SV with a stiff GSXR front end.
  9. #59
    I wasn't referring to spring rate, I was talking about the overall stiffness/flexyness of the forks themselves, and how much of that gets transferred to the frame as a result.
    I got your point. I actually came across cases of people removing the steering damper at the isle due to it making the bike unrideable.
    Um, yeah, it surprised me how much I liked it, too. :-0
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Glad you guys enjoyed my stiffness!!!
    This one?
    I SO want the upper left RVF!
  14. #64
    Hiram, ME
    The bike Bill's referring to also had a GSXR front end, for whatever that bit of info is worth.
    That may be, I don't know the specifics for SVs or lobotomized Ninjers, just pointing out that there is a point where you can go too far so talk to people with experience who may have found that line.
  1. Front Brake Pad Swap
    By pontifex in forum Bike Maintenance
    Last Post: 07-01-13, 11:10 AM
  2. looking to swap the front end of my bike
    By jbman1983 in forum For Sale
    Last Post: 09-04-09, 02:47 PM
  3. Front wheel swap @ 50pmh
    By schleppy in forum General Bike Related
    Last Post: 03-05-09, 03:57 PM
