Results 1 to 11 of 11
Fuel Tank Repair
    Central MA
    Fuel Tank Repair
    I just picked up a 1996 DR650 with only 3000 miles on it. It had been sitting in a barn for a couple of years. I had to give the carb a good cleaning before it would run, but it seems to run well now.
    I have found that it has a fuel leak from the lower right hand seam of the tank (stock, steel). The seam is covered with a thin black moulding that I have yet to pull off. When looking into the tank, I can see some rust on the frame hump, but I have seen much worse.
    I am looking for recommendations for repair. I have never used any liners, such as Kreem, POR-15, or Caswell's, but I have been told that it must be at least 60 degrees to use any of these (my garage is not heated).
    I have also been considering Permatex fuel tank repair, which would possibly allow me to repair the tank from the outside without creating an eyesore.
    The tank is beautiful, and does not have a scratch on it, so I would like to preserve it one way or another.
    Thanks!
    Lifer DuncanMoto's Avatar
    Re: Fuel Tank Repair
    Get the seam welded and Kreem the inside of the tank.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    How about fiberglass and plastic tanks?
    Central MA
    I have access to a TIG welder, but I am concerned about messing up the beautiful stock paint job.
    I have also considered purchasing the IMS (4.9 gal?) tank for this bike, but I really did not want to invest the $250+.
    So, this is all about saving the stock tank at this point. I was curious to see if anybody here had any experience with sealers or liners.
    Central MA
    For those curious, here is what it looks like:
    Nice bike, but it looks like your kickstand is leaking oil.
    Be very very careful if you go near that tank with a welder. Even old old gas in tiny quantities can make a big big boom, especially in small quantities that vaporise.
    Central MA
    Yes, that is a small spot of melted snow that the kickstand is sitting on...
    As far as the big *Boom!*....yes, I am aware of that as well. I hope to get the tank off and remove the moulding this weekend to get a better idea of what I am dealing with here. While the tank is off, I will remove the carb again and drill out the fuel screw plug to richen up the idle a bit. I have read that I should also remove the screen in the carb fill spigot, as it can lead to problems down the road.
    While the tank is off and empty, I will remove the entire petcock assembly and clean the inlet filters, as well as the entire tank out really well.
    This bike is intended for my daughter, who wants to move up from her Ninja 250. I intend to lower the 650 with the factory recommended procedure.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    x2
    kreem goes on THICK, I would think that would solve all your problems, a safe and (not so easy) way. get a bunch of SS hardware (nuts, bolts, washers, whatever)... then you pour something that will help break up the rust, and shake the tank for... ohh, a couple hours. Then apply kreem - it's pretty damn thick, and i may be wrong, but I think you can apply more than once if you want a thicker liner.
    Central MA
    Thanks, Kitt. I have read the "insert screws and shake" recommendation as well.
    Have you used the Kreem liner method yourself? If so, how long did the entire process take?
    I saw a HD tank with a "failed" Kreem liner attempt, and it had large, hard, chunks of the stuff rattling around in the tank, with well over 50% of it still attached to the inside of the tank. I do not want to end up there!
    I read that the Caswell stuff is an epoxy type, and it remains somewhat flexible after it is cured.
    Posting Freak FAST GSXR750's Avatar
    Granby Ct.
    I had a radiator shop weld the tank on my 81 gs then they sealed it right there. Cost about $100. They cleaned it and pressure checked it after also. The seam had like 6 or so rust thru spots.
    GSXR750 GS650 Street Tracker
  1. For Sale - Parts & Tools | Anyone looking for a G1 SV fuel tank
    By The Snowman in forum For Sale
    Last Post: 02-25-14, 11:44 AM
  2. Fuel tank welder?
    By Garrett in forum Bike Maintenance
    Last Post: 11-04-13, 10:15 PM
  3. White yz 125/250 fuel tank
    By seth399 in forum For Sale
    Last Post: 04-04-11, 02:54 PM
  4. first gen sv650 fuel tank
    By PPS26 in forum For Sale
    Last Post: 12-21-08, 10:44 PM
  5. WTB First Gen SV fuel Tank
    Last Post: 07-22-08, 01:47 PM
