Results 1 to 15 of 15
Funky clutch fluid
    Jun 2005
    Funky clutch fluid
    So, here's the diggedy-deal...
    My Superhawk has a hydraulic clutch (and blinkers). I changed the clutch fluid (DOT4) at the beginning of the season, b/c it was kinda brown... actually it was good and brown. "Shit brown" you could say. So, I changed all the fluid in the reservoir and bled the hell out of it until it was back to it's normal color: piss yellow. The world was a good, happy place again. Unicorns and sunsets and dolphins and shit. Well, cut to now and the world is now a shitty brown place again... clutch fluid is back to it's previous brown color.
    No leaks in the system. Seals look great at both ends. Gasket around the slave is fine, no motor oil or DOT4 visible anywhere. No funk on the actuating rod. Bike is a little over a year old. Fluid is about 4K old...
    Is this normal?
    Waterbury, VT
    Funky clutch fluid
    You're fine as long as it isn't leaking, and everything is working OK. Replace all the brake fluid in your bike every couple of years anyway just for good measure. I switched over to ATE Blue in the car and the bike and have had great results. It appears to break down a lot less (and has the bling factor of being blue).
    SSearchVT
    KB KB's Avatar
    Manchester NH
    Funky clutch fluid
    Here is why your clutch fluid turns shit brown.
    The slave cylinder is attached to the engine and is subject much highe and constant temps turning it shit brown faster than you can say Yeah Boyyyyyeeeee.
    I have the same bike. Leave it brown, don't bother changing it again.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer LuvDog's Avatar
    Ashland, MA
    Funky clutch fluid
    It's similar on the Duc too.
    I changed mine and it was nice and clear... you could hardly even tell there was fluid in the rexervoir. 100 miles later and it's honey brown... shortly after it's like molasses.
    It's normal, but I also think because of the temp extremes and use that it should be changed more often.
    I'll do mine every spring.
    2003 ZX7R
    1995 916
    Senior Member MsHap's Avatar
    Funky clutch fluid
    Jello's turns brown in a week too.
    Do not worry.
    I want the Blue kind now!
    My Name is Chrissy
    This is Jello
    Have you hugged a corner today?
    Funky clutch fluid
    OK I ordered the Blue one
    My Name is Chrissy
    This is Jello
    Raymond NH
    Funky clutch fluid
    The real culprit is the amount of fluid that's pumped on each pull pf the clutch. You are pulling the lever all the way to the bar every time and moving much more fluid down the line. When you release the clutch, the same amount of fluid comes right back up the line and refills the reservoir. This allows the hot and brown fluid to mix with the nice clean fluid on every clutch pull.
    Brakes discolor the fluid just as much or more but it all stays in the calipers since there's hardly any fluid movement when you apply and release the brakes. Also as the brake pads wear, the fluid in the reservoir slowly goes down, filling the void left by the worn pad material. There's almost no upward movement of brake fluid until you compress the caliper pistons to install new pads. At that point, the fluid in the reservoir will become decidedly nasty colored.
    I'm with the change it every couple of years crowd.
    Central VT
    Funky clutch fluid
    The only true cure is to paint your reservoirs black........ Change it every 200 miles or every 20k miles, you probably won't feel a difference. Ya might but it will most likely be minimal.
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Funky clutch fluid
    That blue stuff, stays blue. It is cool
    My Name is Chrissy
    This is Jello
    Ashland, MA
    Funky clutch fluid
    Now I want the blue stuff too.
    2003 ZX7R
    1995 916
    Funky clutch fluid
    I bought like a gallon.
    You can have some
    My Name is Chrissy
    This is Jello
    Ashland, MA
    Funky clutch fluid
    You can have some
    2003 ZX7R
    1995 916
    Central VT
    Funky clutch fluid
    My blue stuff turned green..............
    Jake
    2006 ZX-10R
    Funky clutch fluid
    lol
    Is it sick?
    My Name is Chrissy
    This is Jello
    Central VT
    Funky clutch fluid
    It doesn't have a temperature or anything.........
    No difference in feel just kinda funny to have one blue(brake m/c) and one green(clutch m/c).
    Jake
    2006 ZX-10R
  1. Funky new electric cycle
    By FriskyDingo in forum General Bike Related
    Last Post: 10-26-20, 12:12 PM
  2. 07 Husky TE450 Clutch Fluid
    By LXnastynotch93 in forum Bike Maintenance
    Last Post: 04-19-19, 05:14 PM
  3. Dual clutch fluid reservoirs?
    By xxaarraa in forum General Bike Related
    Last Post: 08-01-17, 11:44 AM
  4. WTB: GSXR clutch lever & front brake fluid resevoir.
    By OreoGaborio in forum For Sale
    Last Post: 05-24-09, 05:07 PM
  5. Ducati Multistrada; Funky Design Exercise or Real McCoy?
    By DH2ML in forum General Bike Related
    Last Post: 08-10-03, 07:35 PM
