Results 1 to 4 of 4
FZ6 stuck in neutral?
    May 2013
    Wu-town
    The shifter link has come unscrewed (at the transmission end) twice in the 500 miles since the new chain. I just screwed it back in, and the bike won't leave neutral, to first or second. It'll move, but it springs back to neutral.
    Took off the shifter link, tried by hand. Same result.
    Bike is an '04 with 13k miles. Any input would be appreciated
    May 2013
    Wu-town
    Re: FZ6 stuck in neutral?
    UPDATE: Fixed it. Bike needed to be running to get it into gear. It was still a hard *clunk* to get it there, but it works
    Yup, that's normal, the clash box depends on movement to get things to align. If you're trying to shift with the bike on it's sidestand, good luck. Get the rear in the air so you can rock the wheel back and forth while you work the shifter and it'll work better.
    Littleton, Ma
    you could have called me pat and saved yourself some time
  1. No Neutral
    By slammp in forum Bike Maintenance
    Last Post: 03-12-12, 08:57 AM
  2. Do you shift into Neutral at red lights?
    By mace in forum General Bike Related
    Last Post: 03-04-12, 01:05 PM
  3. Finding neutral
    Last Post: 06-30-11, 03:23 PM
  4. Rpm's = acceleration false neutral ???
    By sluggah in forum Bike Maintenance
    Last Post: 08-11-10, 06:43 PM
  5. R1 Neutral Position Switch?
    By highsider in forum Bike Maintenance
    Last Post: 04-05-05, 09:28 AM
