Results 1 to 11 of 11
Gas tank rust, fix or not...
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Okay, this isn't off my bike but I got a new gas tank for my 3000GT and there is some verry light rust inside. Should I bother with a rust treatment/acid bath or just fill it and run it?
    The worst part is the filler hole which I could get to by hand easily.
    Don't want this to be a big project but I have the tank out and I'm on the fence...
    05GSXR75005SV65090DR350
    Lifer golden chicken's Avatar
    Fitchburg, MA
    Re: Gas tank rust, fix or not...
    I say fill it and run it.
    Mar 2016
    Falmouth, ME
    Kind of what I'm leaning toward.
    Lifer LuvDog's Avatar
    Ashland, MA
    Tough one... it doesn't look bad at all. For me, I'd probably get my soda blaster out and give it a quick hit.
    If I didn't have my soda blaster, I'd probably just get to any easily accessible parts and then fill and go.
    2003 ZX7R
    1995 916
    Yeah, run it. Anything you hit it with will likely flash rust even worse than that before you get gas in it.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Mar 2016
    Falmouth, ME
    I threw a little vapo rust in then rinsed with gas. Yeah, didn't want to mess with treatments or rinse with water, the rust is pretty mild.
    Definitely cleaned up the rust spots at the bottom and some other crap, nice clean gas in it now.
    Fitchburg, MA
    Is there an external fuel filter you can change in a few hundred/thousand miles? That'd probably be ideal.
    Mar 2016
    Falmouth, ME
    Yep. Screen in the tank and external filter by the engine. Actually replaced the gas tank, pump, sender, fuel filter + assembly & S/S fuel line from tank to engine.
    If she lives a few thousand miles, I'll change the filter.. 290k miles
    Fitchburg, MA
    Yeah. Run it.
    Mar 2016
    Falmouth, ME
    Yep. She's running again. That old tank was a mess
    Ashland, MA
    Nice... I always like the 3000GT.
    2003 ZX7R
    1995 916
