Results 1 to 13 of 13
Quad Sport carburetor issue.
    Dean
    Central Mass
    I have a 2008 Suzuki LTZ 400 that has been garaged for several months. Everything works fine until I give it throttle and it stalls. I'm pretty sure it is a dirty or clogged carburetor. Central Mass Powersports charges $250 for cleaning but I want to exhaust my options before taking that direction. Suggestions welcome.
    Dean
    Re: Quad Sport carburetor issue.
    Pop the carb and clean it yourself? Price - Can of carb cleaner and time. Based on description, if you can start it and get it idling without choke you've got a plugged main jet. Pop the carb off, pop the bowl off, remove main and soak in carb cleaner until the passage is clear. Re-assemble and test.
    Douglas Ma
    A single carb is a piece of cake. No synching to do. Just disassemble, spray the shit out of everything, reassemble. Ride.
    I am Dead now
    Oct 2009
    The tax State of the Nation
    And also don't spray the carb cleaner on any rubber O-Ring or any rubber seals, as it will take all of the oil in that rubber & turn it to dust.
    Dean
    Central Mass
    Quote Originally Posted by bstnsboy View Post
    Google and YouTube. Now I have to find the time. Anyone has any experience with C-foam? That was a suggestion at the shop.
    Dean
    Lancaster
    C-Foam helps to keep clean but i do not feel it would unclog a jet, its really not hard to pull apart and clean, i live in Lancaster, if you want some help send me a PM
    Corey
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Seafoam is usually good to keep this from happening, but once clogged won't usually clear it (as it would have to get through the passage to the clog, which it can't).
    You can try, but you'll probably end up pulling the carb (as others have said).
    Lifer Stromper's Avatar
    Eastern Ct
    Did you let it warm up
    The calculus of hate
    Dean
    Central Mass
    I did let it warmed up. The quad drives in Prim but in Run or Reserve, it stalls. I noticed when I press the throttle fast and hard, it throttles but if I ease into the throttle, it stalls. I think you guys are right, it has to be clogged somewhere. It doesn't look to hard disconnecting the carburetor but it sure is in a tight space.
    Dean
    it's not getting enough gas!!!
    Vacuum leak to the petcock. Hose or something else is letting air in.
    once you get it runnin right, put a valve in the fuel, stop the engine by letting it run itself out of gas, drain the float bowl, don't leave any ethanol gas in the carb to gunk it up again
  1. Where do these go on my carburetor?
    By Gman021 in forum Bike Maintenance
    Last Post: 05-12-15, 01:30 PM
  2. 2004 ltz400 sport quad
    By gus310 in forum For Sale
    Last Post: 07-18-13, 10:26 AM
  3. Alpha Sport 250 issue
    By Aimy77 in forum Bike Maintenance
    Last Post: 01-17-10, 12:38 AM
  4. WANTED: Sport Quad...
    By Stoneman in forum For Sale
    Last Post: 06-11-07, 09:23 PM
