Page 5 of 7 FirstFirst 1234567 LastLast
Results 101 to 125 of 159
The (not so) Great Gixxer Rebuild
  1. #101
    Re: The (not so) Great Gixxer Rebuild
    Quote Originally Posted by BCT748 View Post
    Did you frost your tips yourself?
    frost my tips
    it's called bed head on christmas morning
  2. #102
    Lifer stevecbr900rr's Avatar
    Sep 2006
    Malden, Mass
    Just caught this thread tonight props to you. Its nice to get an education from someone who knows there shit and when they let you do the work its even better. Great job bud you did allot of work on that baby it must feel good...)
    1993 Honda CBR900RR
    1990 Suzuki GSXR1100
    1992 Kawasaki ZX750
    1996 Honda F3 Trackbike
  3. #103
    thanks steve, although i have a Day 4 coming next week
  4. #104
    Nov 2007
    Zip-Tie Alley Racing
    LRRS/CCS #103
  5. #105
    Quote Originally Posted by ceo012384 View Post
    nothing major, just what i was telling you about on newbury last night. new(er) front tire, pads, and installing the rear SS lines.
  6. #106
    Nov 2007
    You need to check out that brake return spring or whatever is causing the brake lever to have a shitload of play before putting any pressure on the fluid... once you get the lever in it feels good but there is a lot of slop beforehand.
    And get all that ghey chrome off while you're at it.
    LRRS/CCS #103
  7. #107
    thanks, i'll ask Degs when I go back to the garage next week
    i will, as soon as you wipe off all that ghey on your face
  8. #108
    Sep 2006
    Malden, Mass
    You and Chris are starting to act like an old married couple...
    1993 Honda CBR900RR
    1992 Kawasaki ZX750
  9. #109
    Quote Originally Posted by stevecbr900rr View Post
    steve, be fair. i think Blake wants in on the special bond that chris and i have
  10. #110
    Nov 2007
    I Jim
    LRRS/CCS #103
  11. #111
    Meriden, Ct
    I Jim
    Has Denno finally lost all elasticity in his sphincter?
    Sep 2006
    Malden, Mass
    ...Everyone needs a little Bromance now and then.
    1993 Honda CBR900RR
    1992 Kawasaki ZX750
  13. #113
    Nov 2007
    When he farts now it just sounds like a light breeze *whoooosh*
    LRRS/CCS #103
  14. #114
    Meriden, Ct
    I kept trying to tell him that being SXLova's bottom was gonna ruin it. He didn't want to listen.
    Foxboro, MA
    this is not the great sphincter re-build thread
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
  16. #116
    Meriden, Ct
    Quote Originally Posted by Crash Dummy Denno View Post
    Obviously...
    Some things simply can not be rebuilt...
    Day 4:
    Picked up my new SBS brake pads for the front from Bettencourts
    The (not so) Great Gixxer Rebuild-2008-08-21-2-jpg
    after taking the 2 bolts off for the caliper, remove this hex nut with a 5mm allen wrench. this is the pin that holds the 2 pads in the caliper
    The (not so) Great Gixxer Rebuild-2008-08-21-3-jpg
    install the new pads, and put the pin back in the caliper to hold the pads. if you used your front brakes before taking the caliper out, your pads will probably look close together like this.
    The (not so) Great Gixxer Rebuild-2008-08-21-4-jpg
    very carefully, get a flat head screwdriver between the pads and pry them apart. this will make it easy to get the caliper back on the rotor.
    The (not so) Great Gixxer Rebuild-2008-10-02-5-jpg
    here's the view of the old & new pads
    The (not so) Great Gixxer Rebuild-2008-08-21-6-jpg The (not so) Great Gixxer Rebuild-2008-08-21-8-jpg The (not so) Great Gixxer Rebuild-2008-08-21-9-jpg
    put the 2 caliper bolts back in with a 12mm socket and torque them to 18.1 ft/lbs (this one's for you garage guy)
    The (not so) Great Gixxer Rebuild-2008-08-21-10-jpg
    the old stock Tokico pads
    The (not so) Great Gixxer Rebuild-2008-08-21-11-jpg
    Make sure you pump your front brakes before riding. I broke the new pads in as suggested by Degsy. Go 30MPH down the street, and go to an almost complete stop. Repeat 5-6 times.
    After I finished the pads in the driveway, I rode to Degsy's to do the rear brake lines.
    Remove the brackets holding the line to the swingarm with an 8mm socket & take the top cover off the rear brake reservoir.
    The (not so) Great Gixxer Rebuild-2008-08-21-12-jpg
    After loosening the bolt on the caliper with a 12mm socket, drain the old brake fluid into a pan & pump the rear brake.
    The (not so) Great Gixxer Rebuild-2008-08-21-13-jpg
    Once all the old fluid is gone, remove the 12mm bolt off the brake line at the reservoir & take the line off the bike.
    The new brake lines came with new crush washers & 14mm bolts. Make sure to use a new crush washer on both sides of the brake line & then torque the bolts to 16.5 ft/lbs.
    Reuse the rubber grommets from the OEM brake lines & install them on the new lines. Install the brackets that hold the lines to the swingarm.
    The (not so) Great Gixxer Rebuild-2008-08-21-13-jpg The (not so) Great Gixxer Rebuild-2008-08-21-14-jpg
    Once everything is bolted back up, fill the rear reservoir with new DOT4 brake fluid and start bleeding rear brake.
    The (not so) Great Gixxer Rebuild-2008-08-21-15-jpg
    once all the air pockets are gone, you're good to go
  18. #118
    live to ride seth399's Avatar
    Feb 2007
    CA
    just FYI but I would recommend pushing the caliper pistons back out without the pads in. Like you said its fine if you are very careful pushing on the new pads but its a good idea to push them out with the old junk pads in or without pads at all.
    Quote Originally Posted by seth505 View Post
    ya i thought of that when i bolted everything back in. then i got lazy and did it with the new pads in anyways
  20. #120
    Foxboro, MA
    got one better for you - if you can let the pads sandwich together and sit on one side of pistons, then you can pry from the backside of the pads - at least thats what i can do on my 636 - then no chunks taken out of your pads
    nice work jimbo, did you leave some air in the rear line to leave the brake a bit soft? just wondering as i know how you love doing stand-up wheelies and how you always cover your rear brake.
    Denno
    2006 Yamaha R6
  21. #121
    Nov 2007
    Yay Jim!!!!!
    And THAT one is for Denno... (T1 )
    One of the important things if you ask me is to use a toothbrush and brake cleaner to clean the shit out of the caliper pistons before you push them back in. All that grime on the pistons isn't good for the piston seals/orings.
    You can use emory paper, alternately.
    LRRS/CCS #103
  22. #122
    last update for this thread. my bike is now ready for that 225 mile ride in NH i''m doing next weekend. Got my new A* boots and SPIDI Penta gloves, and now it's time for a new(er) tire. My front tire was done, so swapped it out for another one with better tread.
    Old vs New - Michelin Pilot Power 120 tire (non 2CT)
    The (not so) Great Gixxer Rebuild-aug-31-2008-nhms-004-a
    took the front wheel off and had Boston Moto mount the tire for me. thanks again guys
    The (not so) Great Gixxer Rebuild-aug-31-2008-nhms-006-a
    the tire wasnt new, but was very slippery on the ride home form NHMS. Took a good day of riding for it to feel sticky again. Thanks everyone for their comments & feedback on this thread.
  23. #123
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    your pictures = borked
    -Benjamin Franklin
  24. #124
    Quote Originally Posted by daviid View Post
  25. #125
    Feb 2007
    CA
    pics worked for me!
  1. first 2 stroke rebuild
    By black in forum Dirty Bastards
    Last Post: 01-25-17, 05:24 PM
  2. R6 caliper rebuild
    By Dip Dungles in forum Bike Maintenance
    Last Post: 02-19-13, 07:14 PM
  3. Great Ride Sat with great friends
    By GingahNinjah in forum General Bike Related
    Last Post: 05-21-12, 06:26 PM
